anyone using a holley HP or dominator system #2556386
09/29/18 08:39 PM
09/29/18 08:39 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
I have a 2012 5.7 for my 69 charger. looking at the HOLLEY HP system but it will be supercharged so leaning towards the dominator. after talking to Holley tech, anyone using one of them.
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: anyone using a holley HP or dominator system [Re: sparcy] #2557953
10/02/18 09:46 PM
10/02/18 09:46 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
I'd go with the hp, we use and sell them all of the time. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: anyone using a holley HP or dominator system [Re: sparcy] #2558152
10/03/18 11:00 AM
10/03/18 11:00 AM
Charleston SC
Fishstix Offline
Fishstix  Offline
Charleston SC
I am hooking a HP up now for my 6.1
It came highly recommended from one of the guys at Blueprint engines a while back.
The Holley system seems a bit pricey with all the harnesses.
Re: anyone using a holley HP or dominator system [Re: sparcy] #2558749
10/04/18 04:33 AM
10/04/18 04:33 AM
I used a Holley Dominator EFI with dual 1150 CFM 4150 type throttle bodies on a gen 2 pump gas street Hemi 572 C.I. for a local street show and drive 1970 Challenger, I was told by Rich at Fastamn EFI that unit was capable of being used in the future for a boosted application, if the customer wanted to do that. Can you say twin turbos devil
Not so on the other Holley EFI units last year when I bought it work
Sometimes it pays to buy more than you need just in case up twocents
Re: anyone using a holley HP or dominator system [Re: sparcy] #2558779
10/04/18 09:24 AM
10/04/18 09:24 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
use the HP at work for many boosted/NA combos at work. Unless you need drive-by-wire or a ton of I/O, the HP should work well.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: anyone using a holley HP or dominator system [Re: sparcy] #2558941
10/04/18 03:54 PM
10/04/18 03:54 PM
Charleston SC
Fishstix Offline
Fishstix  Offline
Charleston SC
I was sold on the HP as well as it would support a SC which I may do in the future.
Re: anyone using a holley HP or dominator system [Re: sparcy] #2558966
10/04/18 04:44 PM
10/04/18 04:44 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Another option is megasquirt ms3 gold, around 1300 for everything including the harness/ecu and fully tune able for boost.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: anyone using a holley HP or dominator system [Re: sparcy] #2558981
10/04/18 05:28 PM
10/04/18 05:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The EFI Source MS3 Gold Box is a good value, a friend bought a car from a member here that had that setup. He did have an issue with the coil driver and EFI source was quick to help diagnose and test to help him find the issue.
68 Barracuda Formula S 340
Re: anyone using a holley HP or dominator system [Re: sparcy] #2559706
10/05/18 11:47 PM
10/05/18 11:47 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I went with the Dominator because it has a lot more parameters that can be tuned. I can use the drive by wire from my donor car and my automatic trans can be tuned with it also. Both are good products and user friendly.
Re: anyone using a holley HP or dominator system [Re: sparcy] #2561276
10/09/18 04:13 AM
10/09/18 04:13 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I sell and support the Holley EFI products and I'm Holley certified. I also teach classes and offer a fairly inexpensive ($75) online course that has been a lot of help for people starting out with Holley. I sell the HP as a kit with all the harnesses, etc. included. The Dominator is ala-cart. The HP is the same internal ECU as the Dominator with the same software. The Dominator adds: much more I/O, DBW, dual wideband support, and auto transmission control. If you're a racer get the Dominator because all the extra I/O means you don't have to buy a separate data logger. Call me with questions.
Re: anyone using a holley HP or dominator system [Re: sparcy] #2561491
10/09/18 05:10 PM
10/09/18 05:10 PM
ghinmi Offline
ghinmi  Offline
I have Holley HP on my turbocharged 5.7 Eagle hemi. 2.5 years so far, 22k miles, two Drag Weeks, etc. Not a single hiccup. Running mid 10s in a 4000 lb Jeep.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: anyone using a holley HP or dominator system [Re: ghinmi] #2561496
10/09/18 05:24 PM
10/09/18 05:24 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Haven't see you post here in a while, saw the live feed and looked like the jeep was running pretty good. thumbs
Re: anyone using a holley HP or dominator system [Re: sparcy] #2561956
10/10/18 03:07 PM
10/10/18 03:07 PM
ghinmi Offline
ghinmi  Offline
Thanks! She was running pretty good considering the mediocre weather. I was being pretty soft on the launches because of how far away from home I was. Hopefully get a chance in the coming weeks to see what it'll run all-out.
Re: anyone using a holley HP or dominator system [Re: sparcy] #2562157
10/10/18 09:58 PM
10/10/18 09:58 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
thanks street car 5.7 whipple going to need trans controller
