Page 3 of 6 1 2 3 4 5 6
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555171
09/26/18 07:51 PM
09/26/18 07:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I been saying it for years... a magnum block has more meat where it is needed and is at least harder if not stronger iron as well as more consistant castings. I even posted pictures and nobody seems to care, now I cant post pics anymore so you would have to look back a couple years in my old posts.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555175
09/26/18 07:59 PM
09/26/18 07:59 PM
Washington
madscientist Offline
Washington
Originally Posted By B3422W5
Just talked to Jack..... little more info he doesnt mind me sharing.
Bullet cam. He consulted with Tony at BES regards it. One of Tony’s former guys, John Lohone( sp) now works for Jack and will make the trip down with him. One time Nascar engine builder
He said the valves clear with a ton of room. Very well centered in the bore, a big positive for the heads. Said they would clear a stock bore
That Holley manifold was indeed only made for W2. He has about 40 hours converting it from oval to square. Tons of work involved there. I had thought they must have offered it in a standard head form at one time, but just W2
Using cyro treated Hughes rockers. Really likes them.
Told me he made a plate for the front of the timimg cover where he can pop off the water pump and move cam in not much more than ten minutes. Said the motor is ultra sensitive to cam timing. Currently has it advanced 4 degrees, makes 750 this way but good bit more torque. Couple degrees can make or take 20 horsepower
Is likely to move it around down in Charlotte.
Said it will break 800 horse spinning it to 8k. Some very trick oiling mods. Had it on Bischoffs dyno recently and Tony told him it had the capability to win the competition. Was very impressed.
Yeah, every bit of 40 hours to get a Pro Dominator square. Usually takes some welding too.
Re: 771 horse stock stroke 360 motor, pump gas [Re: HotRodDave] #2555179
09/26/18 08:03 PM
09/26/18 08:03 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Funny you would say that.
Jack told me the metallurgy in the magnum blocks is better. Said they are notably harder, and extra meat to use 4 bolt splayed caps up
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: madscientist] #2555180
09/26/18 08:04 PM
09/26/18 08:04 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Yep, he did lots of welding
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: HotRodDave] #2555182
09/26/18 08:13 PM
09/26/18 08:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can still post pics.. your just doing it
wrong.. after you make your post just click on
file management then click on browse.. on your
computer find your pic.. then add the pic..
then hit add then finish it off like you normally
would by hitting submit... very simple but doing it
this way I have all my pics on MY computer first
wave
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555193
09/26/18 08:41 PM
09/26/18 08:41 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Motor
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555196
09/26/18 08:42 PM
09/26/18 08:42 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
First picture i have tried, nothing happens when i click on it
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555233
09/26/18 10:00 PM
09/26/18 10:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I cant finger out how to get them from phone to cunfuser and when I try to add em straight from stupid phone its telling me something about 2 terrebytes too big or something
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555249
09/26/18 10:34 PM
09/26/18 10:34 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I just stopped by the machine shop to check my new 318 build. They are building a stock block 340 that will make 700 + with Pro Charger. Pro Gram 4 bolt main caps and the outer bolts are re-positioned at an angle to pick up more meat in the block. This really saves on buying an X or R block.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555290
09/26/18 11:18 PM
09/26/18 11:18 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yikes 40 hours on the Pro Dominator, I have one that is converted to EFI and I would love to run some Victors but that is a lot of work it sounds like.
68 Barracuda Formula S 340
Re: 771 horse stock stroke 360 motor, pump gas [Re: MR_P_BODY] #2555309
09/26/18 11:50 PM
09/26/18 11:50 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
wave
Pictures do not work for me either. something to do with the new iPhone so I just gave up
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 771 horse stock stroke 360 motor, pump gas [Re: A/MP] #2555311
09/26/18 11:53 PM
09/26/18 11:53 PM
P
Porter67 Offline
Porter67  Offline
P
People should not confuse themselves into thinking a oem block can even come close to what a X or R is or can take.
The main webs, the filled inner pan rails, the thicker decks, cylinder wall thickness. The nickle content.
From side by side on a stand compassion to parts attrition on freshen up its all easily spotted.
The main reason we see x or r blocks in these times that cant go 4.100 safe is because they are seconds from the days when they were easy to get and were set aside from core shift as culls.
Re: 771 horse stock stroke 360 motor, pump gas [Re: Porter67] #2555374
09/27/18 02:51 AM
09/27/18 02:51 AM
Washington
Washington
Absolutely. There isn't a production block out there, other than a T/A block that should be considered for serious power. The main line will flex like jack the bear so you need to run looser main clearances, the decks are too damn thin for boost (IMHO) and putting 4 bolt caps on ANY production block is a desperate act. In fact, I won't do it. There isn't enough material there, even if you use a 5/16 bolt and it's offset. Isn't worth it as the support isn't there.
AFAIK there is ZERO difference in the cast iron used between LA blocks and magnum blocks. They hone the exact same. They are both harder than a Ford and significantly harder than a Chevy, but they ain't an X or an R block and you'd know it as soon as you hone one.
Other than lack of availability there is no reason to use a production block in a serious power application unless you just can't get something.
Re: 771 horse stock stroke 360 motor, pump gas [Re: madscientist] #2555442
09/27/18 10:42 AM
09/27/18 10:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been giving the idea to sleeve all 8
on my TA block... its the last one I have
and they are hard to find any of them but
it would be a good block then.. the last
sleeve I had done was $110 a hole so I would
guess its about $1000 to do all 8 now days
wave
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2555464
09/27/18 11:26 AM
09/27/18 11:26 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Use studs, add bolts, whatever. When what you are bolting it to is flimsy, the benefit is limited. When the mating surfaces are fretted, the caps are dancing around.
Re: 771 horse stock stroke 360 motor, pump gas [Re: pittsburghracer] #2555473
09/27/18 11:40 AM
09/27/18 11:40 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By pittsburghracer
I’m sure all the info isn’t out there on this dyno Queen yet.
My understanding is that the current owners plan for this engine is to race NHRA Super Street. However plans can change. He and his family have lots of experience racing Stock and perhaps Super Stock.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556282
09/29/18 02:32 PM
09/29/18 02:32 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Any idea what the valve stems Dia is ?
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 771 horse stock stroke 360 motor, pump gas [Re: ric3xrt] #2556289
09/29/18 02:59 PM
09/29/18 02:59 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Hollow stem, but dont know the diameter
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556324
09/29/18 05:03 PM
09/29/18 05:03 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
very impressive for sure but it states 100 octane like one other person stated earlier. i don't know what pump that's from. just saying. my thought would be 93 octane at best if pump gas is the claim. excluding e85.
Re: 771 horse stock stroke 360 motor, pump gas [Re: 9secondsatellite] #2556333
09/29/18 06:04 PM
09/29/18 06:04 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Motor runs on pump swill but the competition fuel is 100 octane
1.41 best 60 foot
6.60 at 103.90 1/8
