340 six pack idles too fast after reinstallation
#2556278
09/29/18 02:11 PM
09/29/18 02:11 PM
Posts: 364 US
f2502011
US
My divorced choke wasn't working correctly so I had to take it off to adjust it. Unfortunately one of the bolts broke off so I ended up having to remove the carbs to get to that bolt to fix it. Got everything back together. I didn't mess with any adjustments on the carbs because it ran fine before just hard to start due to lack of choke.First crank up and it idles way too high like 3000 RPMs. What did I mess up and how do I fix?
1970 EK2 T/A 727
Re: 340 six pack idles too fast after reinstallation
[Re: f2502011]
#2556296
09/29/18 03:21 PM
09/29/18 03:21 PM
Posts: 406 California City, CA
dart440
California City, CA
Now that your choke is working, you need to set the "high idle" speed on the fast idle cam. Service manual says: - Engine off. - Transmission in Park or Neutral. - Open throttle slightly. - Close choke plate until fast idle cam tang can be positioned on the second highest step of the cam. - Start engine and determine the stabilized speed. - Bend the fast idle tag with a screwdriver placed in the tag slot to set to the specified speed (M/T 2600 RPM, A/T 2800 according to 71 Ply SM). - Caution: Bend tag perpendicular to the contact surface of the cam. Bend only when the tang is clear of the cam. - Stopping the engine between adjustments is not necessary. However, reposition the fast idle tang on the can after each speed adjustment.
The service manual has a good pic of them making the adjustment. If you don't have one, recommend you get a copy of the factory service manual for your car.
When you work on Spaceships for a living, how bad can a workday be?
[Re: dart440]
#2556303
09/29/18 03:44 PM
09/29/18 03:44 PM
Posts: 364 US
f2502011
US
Mine is A/T. Guess I’m just not used to the idle being so high but I guess ~3000 rpms is normal??
1970 EK2 T/A 727
[Re: f2502011]
#2556422
09/29/18 10:16 PM
09/29/18 10:16 PM
dart440
California City, CA
Personally I would lower it some. 2800 RPM is just what it says in the 71 SM.
A lot depends on how you drive it. I would lower the RPM and just warm the car up more before driving it. There are several settings for the choke system to get it to operate properly. Choke, choke pull-off, choke unloader settings, etc...
I always warm my vehicles up before driving them now, but back in the day, people would just hop in the car and drive it...I have my fast idle set about 1800 RPM on my cars.
[Re: f2502011]
#2556507
09/30/18 01:23 AM
09/30/18 01:23 AM
Posts: 364 US
f2502011
US
Can't get the curb idle below 1500 RPMs. Any ideas or suggestions?
1970 EK2 T/A 727
[Re: f2502011]
#2556509
09/30/18 01:34 AM
09/30/18 01:34 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Can't get the curb idle below 1500 RPMs. Any ideas or suggestions? Start back with the mechanical basics during installation, confirm the end carbs are completely closing independent of the linkage, confirm the linkage is installed properly and operates freely, and travel is adjusted properly, are you using an idle solenoid?
[Re: f2502011]
#2556516
09/30/18 01:56 AM
09/30/18 01:56 AM
dart440
California City, CA
You need to see what is keeping the throttle open or causing the high idle.
Check the throttle cable adjustment/transmission kickdown linkage. Is the cable adjusted long enough/linkage not binding and allowing the throttle to close fully? Disconnect them and see if the idle drops. Since you had the carb(s) off, something may not have gone back together properly.
Check to see if the fast idle cam/lever are touching at idle. They should not be touching when engine is warm and choke is fully open (choke plate should be vertical). Next would be the idle solenoid. Disconnect it and see if the idle drops. If the RPM drops, adjust the solenoid. If not, check the base idle screw and see if you can lower the RPM. Check for vacuum leaks.
If none of these things work, check to see if you have manifold vacuum to the vacuum advance at idle (disconnect the hose). If the RPM drops, check the hose connections. You should not have manifold vacuum to the advance unit at idle. If the hoses are connected properly and you still have vacuum to the advance at idle, the throttles are opened too far.
Did you just remove the center carb or all of them?
Take the carb(s) back off and look for anything hanging up the throttle plates (i.e.; throttle plates rubbing on the throttle plate bores in the base, base gaskets hanging into the bores, bent/binding linkage, etc.). If the throttles are open too far, you'll be into the transfer ports in the carbs, not just the idle circuits.
If it idled well before, go back over each thing you touched one at a time...and look carefully for any problems.
[Re: dart440]
#2556587
09/30/18 12:22 PM
09/30/18 12:22 PM
Posts: 364 US
f2502011
US
If it idled well before, go back over each thing you touched one at a time...and look carefully for any problems. Checked the cable and kickdown. No issues there. Fast idle cam/lever not touching at idle warm. Choke fully open. Solenoid works but I have it adjusted to where it never touches. I'll check the other stuff. Ended up having to remove all carbs because certain sections of the fuel lines would not come apart. I will say other than the high idle issue, runs great.
1970 EK2 T/A 727
[Re: f2502011]
#2557231
10/01/18 08:34 PM
10/01/18 08:34 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
OK, one or more of your carburetors isn't closing all the way FOR SURE. Never, ever, ever start up a six pack car without the outboard linkage(s) connected or you can blow the motor (front/back carbs can go wide open with no way to close them). Here's what I would do: 1. Turn the center carb idle screw all the way out (lowest possible idle). I assume you've already done this. 2. See if you can force (gently) the center carb closed any further by hand. If yes, then your return spring may be weak and/or hanging up somehow. 3. Inspect carbs for anything that may have moved & now interferes with any of the carburetors returning to fully closed (vacuum hoses, plug wires, etc.) 4. WITH ENGINE OFF, disconnect the outboard linkage & see if that lets the center carb close even further. If yes, then re-adjust linkage, re-connect & THEN start engine to test.
5. While the linkage is disconnected (see 4), manually move each carburetor by hand gently to see if any one of them is hanging up. It is very common to have a carb/intake gasket hang up the throttle blades on six packs. (fyi-always best to move carbs open/closed while tightening them down to prevent this....nudging carbs/gaskets so each carb moves freely before fully tightening bolts)
If none of that works.... report back & we'll think of other possibilities
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: shorthorse]
#2557342
10/01/18 11:59 PM
10/01/18 11:59 PM
Posts: 364 US
f2502011
US
You disassembled everything up top. Regardless how it ran before it just makes sense to me that you would have to readjust the linkage when it was reassembled. Did you try to start/run the car without the linkage connected? That might tell you whether it's simply the linkage adjustment or something else like a vacuum leak. Readjusted linkage, no difference. It was instinct to disconnect the linkage at idle to see if that was the issue for high idle.
1970 EK2 T/A 727
[Re: PurpleBeeper]
#2557350
10/02/18 12:06 AM
10/02/18 12:06 AM
Posts: 364 US
f2502011
US
1. done 2. can't 3. will double check 4. did/done 5. never thought of that will have to check my gut feeling is that issue probably lies with base gaskets. vacuum hoses all hooked up correctly as far as i can tell. got new Holley gaskets for all carbs. unfortunately had to remove all carbs eventhough i tried everything i could to not have to do so. this is the only thing that's really changed as far as materials go. everything was torqued to spec (200 in/lbs) but still just not sure everything is right there. really don't want to have to remove everything again.........
1970 EK2 T/A 727
[Re: f2502011]
#2557385
10/02/18 01:53 AM
10/02/18 01:53 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
1. done 2. can't 3. will double check 4. did/done 5. never thought of that will have to check my gut feeling is that issue probably lies with base gaskets. vacuum hoses all hooked up correctly as far as i can tell. got new Holley gaskets for all carbs. unfortunately had to remove all carbs eventhough i tried everything i could to not have to do so. this is the only thing that's really changed as far as materials go. everything was torqued to spec (200 in/lbs) but still just not sure everything is right there. really don't want to have to remove everything again......... As for base gaskets,only one's I ever use is the O.E.M. tan composition cardboard .The thin black is fine if both manifold surface and carb base are "perfectly" flat but most are not and they will leak.If you have doubts about the carb base,use a strait edge,you may be surprised.
[Re: 62maxwgn]
#2557786
10/02/18 05:16 PM
10/02/18 05:16 PM
Posts: 364 US
f2502011
US
The ones I took off were the black ones. Ones I replaced with were the same style Holley ones with what looked like a metal insert. Never seen the tan ones where do you get those? I thought originals were the thin black ones from Holley with rear stamped on them.
1970 EK2 T/A 727
[Re: f2502011]
#2557917
10/02/18 08:23 PM
10/02/18 08:23 PM
62maxwgn
Blair County,PA
The ones I took off were the black ones. Ones I replaced with were the same style Holley ones with what looked like a metal insert. Never seen the tan ones where do you get those? I thought originals were the thin black ones from Holley with rear stamped on them. The tan are available from Mopar Performance,that is what you would have had factory installed.
[Re: 62maxwgn]
#2557971
10/02/18 10:09 PM
10/02/18 10:09 PM
Posts: 364 US
f2502011
US
Not trying to start an argument or anything just trying to understand what’s right. Was looking at most recent Roger Gibson catalog and it has:
“NEW! Authentic Holley 340-6 and 440-6 carb base gaskets. Authentic dark color with “REAR” stamped into gasket as originals”
Is this wrong info?? Never seen the tan ones before this is why I ask. They’ve always been dark. The service manual also shows them dark.
1970 EK2 T/A 727
[Re: f2502011]
#2558110
10/03/18 08:09 AM
10/03/18 08:09 AM
Posts: 2,469 Answering the call of the wild
ThermoQuad
Every time i see a six pak post i go get the It's not that complicated. Please post clear - close pictures of the linkage side and the fuel side. There are many scenarios that will cause your problem and it is probably something simple. Stop wrenching and let's look.
