Re: starter won't dis-engage
[Re: 2abodymcodes]
#2556100
09/28/18 09:30 PM
09/28/18 09:30 PM
RapidRobert
there should be no continuity between the large threaded "batt" stud and the mini bolt on brown wire "solenoid" terminal. Same thing on the large/small starter terminals (no continuity). It is a good precaution to pull a batt cable before switching the meter to ohms. EDIT Which I'm sure you will (just a caveat) take off the main cable/brown wire either at the starter or at the SR before testing either component cuz with the wires still connected, if one device has continuity both em at their terminals will show continuity. holler (with) what you find out.
[Re: 2abodymcodes]
#2556116
09/28/18 10:25 PM
09/28/18 10:25 PM
RapidRobert
possibly a flashlight battery/flashlight bulb & several jumper wires with alligator clips. Likely you could take the top of a flashlight & jump from the center terminal of the top battery & the copper "slide" on the side that comes up from the lower battery negative bottom (whichever way is easiest for you with what you have). it wouldn't be near the same voltage but if it does show continuity then you know that that is the problem.
[Re: 2abodymcodes]
#2556169
09/29/18 02:39 AM
09/29/18 02:39 AM
RapidRobert
Do this first: Pull the yellow wire/terminal off of the "ign" terminal on the starter relay then hookup the battery & see if it cranks by itself like it is doing now (with key off).
[Re: 2abodymcodes]
#2556297
09/29/18 03:28 PM
09/29/18 03:28 PM
RapidRobert
Ok, I removed that wire and it no longer cranks. Which wire?, the yellow one? The only way plugging it in could make it crank WO the key on is if the yellow wire/terminal is hot all the time which would point upstream toward the ign sw as opposed to the relay cuz the yellow wire is only hot when the key is turned all the way to "start". (I feel like I missed something).
[Re: 2abodymcodes]
#2557396
10/02/18 02:32 AM
10/02/18 02:32 AM
RapidRobert
Good idea on the tapping (I learned something) & that would (& did) certainly pinpoint the culprit.
