After installing the brake/clutch pedal assembly, the master cylinder, proportioning valve, and brake lines on our on-going Comeback ‘Cuda ’70 Hemi-powered Plymouth ‘Cuda convertible project car, we then install the under dash insulation. Detroit Muscle Technologies “shoddy pad” and the “fiber board” insulation kits are great! They are cut to exact specifications and their fit is spot on. Having great parts and correct tools always make things go so much better.
Read the whole story at Mopar Connection HERE:
