440 Has Whining Sound #2553342
09/22/18 07:48 PM
09/22/18 07:48 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
My old 440 with a 509 cam has been sitting about a year.
Fired it up today, it sounds just like a power steering pump low on fluid.
Sound went away a lot after it reached 180 degrees, but, still real faint in the back ground.
Oil pressure was 80 psi cold, 60 at idle hot.
There is no power steering pump on it, fired it up on test stand.
Has anyone had a noise like this before? Sounded like it was coming from upper end under the intake.
Re: 440 Has Whining Sound [Re: 65Fury440] #2553396
09/22/18 10:44 PM
09/22/18 10:44 PM
P
Porter67 Offline
Porter67  Offline
P
Could be many things.
Id not get too upset yet, if its set a year maybe it just needed to get heat in it.
Id try the same thing tomorrow and see what it does. Some things can a bit angry after sitting a while.
Re: 440 Has Whining Sound [Re: 65Fury440] #2553720
09/23/18 05:16 PM
09/23/18 05:16 PM
Spring Hill Fl
Spring Hill Fl
The sound starts at 2500 on up to 3500. It's weird, sounds just like a power steering pump whine.
Re: 440 Has Whining Sound [Re: 65Fury440] #2553750
09/23/18 06:14 PM
09/23/18 06:14 PM
I've been trying to think of potentials. You might pull the valve cover(s) & use your stethoscope.
Re: 440 Has Whining Sound [Re: 65Fury440] #2553767
09/23/18 06:47 PM
09/23/18 06:47 PM
Spring Hill Fl
Spring Hill Fl
I'm going to pop off the VCs and make sure pushrods are rotating, poke around with the stethoscope. Thought someone might be able to nail it from memory. Thanks for the replies.
Re: 440 Has Whining Sound [Re: 65Fury440] #2553790
09/23/18 07:50 PM
09/23/18 07:50 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Best thing to do after an engine has been sitting up a long time is pull the distributer and prime to oiling system. I hope it's not a cam bearing issue.
Re: 440 Has Whining Sound [Re: 65Fury440] #2553800
09/23/18 08:04 PM
09/23/18 08:04 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Pull the distributor and see what the drive and the cam look like.
Have a great day
Iowan
"obsolete is neat"
Re: 440 Has Whining Sound [Re: 65Fury440] #2553850
09/23/18 10:07 PM
09/23/18 10:07 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe re-torque the intake to make sure it's not sucking air there.
Re: 440 Has Whining Sound [Re: 65Fury440] #2553904
09/24/18 12:04 AM
09/24/18 12:04 AM
P
Porter67 Offline
Porter67  Offline
P
Id go drive it, get it warm and get at it, the problem will show if there is a problem.
A years not that long in the big picture, I used to pull cars out of fields that were there while I was in high school and I seen them from the bus, clean the tank, change oil, install battery and they all ran.
I beat them like stepchildren and then sold them running.
Re: 440 Has Whining Sound [Re: stumpy] #2554150
09/24/18 05:19 PM
09/24/18 05:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had a faint whining noise once in one of my 440's that started never really seemed to effect anything. The one day it started running rough like it was on 6 cylinders. I had to drive it the 20 or so mile home. It was on 6 cylinders, spun a cam bearing & broke the cam shaft on the #4 journal. Cylinders #7 & #8 were not moving. The front 1-6 still ran fine & got me home. LOL. Cut the oil filter open & was filled of bearing material. I had to rebuild it & still going strong today.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 440 Has Whining Sound [Re: 65Fury440] #2554193
09/24/18 07:32 PM
09/24/18 07:32 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Two things, metal to metal rubbing together, no oil. Or Sucking air, that sounds like a squeal, carb will do this too.
Re: 440 Has Whining Sound [Re: 65Fury440] #2555535
09/27/18 01:55 PM
09/27/18 01:55 PM
central il.
second 70 Offline
second 70  Offline
central il.
Any updates?
Re: 440 Has Whining Sound [Re: 65Fury440] #2555626
09/27/18 05:48 PM
09/27/18 05:48 PM
Spring Hill Fl
Spring Hill Fl
I ran the valves, everything is the same as they were set.
All the pushrods spin.
Distributor gear and bushing look normal.
Tightened the carb.
I am going to just ran it, I don't want it to be a cam bearing, but, that is the area it is coming from, even though the noise is noticeably quieter.
Re: 440 Has Whining Sound [Re: 65Fury440] #2555759
09/27/18 11:30 PM
09/27/18 11:30 PM
Chicago
PurpleBeeper Offline
Chicago
Well....you might try some engine flush? Maybe some "smutz" in an oil passage? If you use that stuff, follow directions EXACTLY and only idle the motor for maybe 5 min. & replace oil/filter.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 440 Has Whining Sound [Re: 65Fury440] #2556032
09/28/18 04:33 PM
09/28/18 04:33 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I had a vacum leak off the back of my carb that gave a whine noise
Re: 440 Has Whining Sound [Re: 65Fury440] #2556258
09/29/18 01:33 PM
09/29/18 01:33 PM
central il.
second 70 Offline
second 70  Offline
central il.
Which would get quieter when warmed up a cam bearing or a vacuum leak? none,one,or possible both?
