converter wont seat #2555349
09/27/18 01:26 AM
09/27/18 01:26 AM
waynesboro va
jonesboys Offline OP
waynesboro va
fighting a converter to go all the way in drops in my old trans fine the new replacement not happening splines look good what am i missing
Re: converter wont seat [Re: jonesboys] #2555350
09/27/18 01:28 AM
09/27/18 01:28 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Lockup trans? Converter that’s not?
Iirc there is one spline different between lockup and non
I want my fair share
Re: converter wont seat [Re: jonesboys] #2555354
09/27/18 01:38 AM
09/27/18 01:38 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What's your install technique? assuming you have the correct converter...
Re: converter wont seat [Re: jonesboys] #2555392
09/27/18 04:29 AM
09/27/18 04:29 AM
Which year trans and converter and which type trans?
None of the 727 converters I've installed went in easy runaway shruggy
I stand the tranny up on its tail shaft and then align the pump drive teeth straight up and down and then try to install the converter with the pump drive slots aligned with the teeth on the pump scope
Even then I usually have to rotate the converter back and forth a 1/4 to 1/3 turn to get it to drop down both ways, onto the input drive shaft teeth and then down onto the pump lugs wrench shruggy
I have found that the race converters with the 7/16 holes in the lugs need to be down right at 3/4 inch from the front of the bell housing face to the face of the lugs, the converter flex plate side scope
Good luck, you can do this thumbs grin
Re: converter wont seat [Re: Cab_Burge] #2555428
09/27/18 10:15 AM
09/27/18 10:15 AM
waynesboro va
waynesboro va
dynamic converter 727 bb trans not sure of the year same number splines 24 on the input shaft 27 on the pump drive ive got the trans in a metal can facing up as usual just cant seem to get this beeotch to drop in just wondering if the trans has an issue i have seen that pre 1967 was different
Re: converter wont seat [Re: jonesboys] #2555431
09/27/18 10:24 AM
09/27/18 10:24 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
just when your ready to give up it will drop right in up
Re: converter wont seat [Re: jonesboys] #2555445
09/27/18 10:47 AM
09/27/18 10:47 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've had a couple that fought like crazy for no apparent reason... confused
I don't stand them up anymore...I got my fingers pinched pretty good once when it finally decided to "drop" in... rant
...FAFO...
Re: converter wont seat [Re: jonesboys] #2555448
09/27/18 10:53 AM
09/27/18 10:53 AM
A727Tflite Offline
A727Tflite  Offline
If still vertical - take a clean small screw driver and carefully go past the pump seal and make sure the rotors are free to turn.
I’ve seen them get stuck and if they won’t move and the inner rotor isn’t centered you won’t be able to get the converter in.
Re: converter wont seat [Re: A727Tflite] #2555515
09/27/18 01:12 PM
09/27/18 01:12 PM
moparx Offline
moparx  Offline
i made a tool years ago, from an old converter, to line up the the pump gears. makes it a little easier to get the converter to seat. the monroe book shows this tool on page 79.
beer
Re: converter wont seat [Re: jonesboys] #2555528
09/27/18 01:44 PM
09/27/18 01:44 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Last one I did was fighting so took a magic marker and marked the pump tang location on the converter....it went right in then.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: converter wont seat [Re: jonesboys] #2555678
09/27/18 08:34 PM
09/27/18 08:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lift on the converter pilot slightly with one hand while pushing in and spinning the converter with the other hand.
Doug
Re: converter wont seat [Re: dvw] #2555697
09/27/18 09:17 PM
09/27/18 09:17 PM
waynesboro va
waynesboro va
thanks for all the input believe me i tried them all dont know why but just like bone fish said when i was ready to give up the sum beech dropped in thanks kenny
Re: converter wont seat [Re: jonesboys] #2555815
09/28/18 02:22 AM
09/28/18 02:22 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I did a 73 trans this summer, got a new vert. Would not go in (lugs aligned). got another input and reaction support, stuck them in the vert and turned a couple times till input slid in, vert went right in the trans first try. Never had that problem before.
