MOTOR HOME CAR RAMP TRUCK #2554135
09/24/18 04:37 PM
09/24/18 04:37 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Came across several mid to late 80's and 90's motor homes in very good mechanical condition. Most have under 60 K. Thinking about a home to ramp truck conversion. Any thoughts?
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554142
09/24/18 04:50 PM
09/24/18 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a old ford 600 series that was a flat bed
with nothing behind the cab.. I got a alum car
hauler(went on the cab of a car hauler).. I put
it on the ford chassis.. worked great for a
few years then I sold it.. is there anything
mounted on the chassis your looking at..I also
built up a old Dodge flat bed with a lift gate
that worked halfass.. that was a slant 6 with a
creeper gear
wave
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554260
09/24/18 10:20 PM
09/24/18 10:20 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
They are intact running motor homes. For my work, I've been using box trucks and there isn't much to squaring off the back of the cab. Thought that the same could be done with a motor home or gut the interior and make a ramp door at the back.
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554304
09/25/18 12:23 AM
09/25/18 12:23 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You'll have to do a beavertail, but using a gutted motorhome could be pretty cool and would likely be ignored my prospective thieves.
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554344
09/25/18 02:59 AM
09/25/18 02:59 AM
The first year we raced NHRA stock at the World finals in Ontario, CA(1973 (I think work )The 1972 NHRA Super Stock champion showed up in a conventional school bus with the back cut off hauling his 1962 Pontiac Catalina 4 speed station wagon, no living quarters or divider between the drivers seat and the rear of that bus with the station wagon hanging out.
I'm sitting here now wondering now about unburnt fuel from the exhaust pipe at the rear bumper blowing up into that bus work tsk twocents
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554392
09/25/18 10:57 AM
09/25/18 10:57 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It's a lot of work, will cost more than you think, and will be worth just about nothing if you ever go to sell it. Sounds like a viable plan! (:
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554397
09/25/18 11:16 AM
09/25/18 11:16 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you decide to pursue this, you might also look at some later model salvage units on Coparts or CrashedToys.
Damage can be minor (think hail) and can make for a real bargain. I just bought a '17 motorcycle for 20 cents on the dollar. And it came through with a clean title for some reason.
Master, again and still
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554443
09/25/18 12:22 PM
09/25/18 12:22 PM
Alberta
rustbuckett68 Offline
Alberta
Check to see if they are full frame. My 79 D400 16'MH(440/727/Dana 70) Dodge had the stock style stamped frame rails. Did not think it would support a deck, but I could be wrong.
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2554448
09/25/18 12:39 PM
09/25/18 12:39 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
This guy put a 1963 D200 Crew Cab on top of a 1970s Dodge motorhome chassis to make a retro car hauler.
http://www.1962to1965mopar.ornocar.com/1963-dodge-afx-hauler-replica.html
Re: MOTOR HOME CAR RAMP TRUCK [Re: 67Satty] #2554453
09/25/18 12:51 PM
09/25/18 12:51 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
This is what I want. It has a lift gate and the car goes up top in the rear.
2011 Drag Pak Challenger
Re: MOTOR HOME CAR RAMP TRUCK [Re: 67Satty] #2554550
09/25/18 04:18 PM
09/25/18 04:18 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I can dig that dodge crew cab!
I can't dig the motorhome truck.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2555286
09/26/18 11:12 PM
09/26/18 11:12 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
The ramp trucks that are in my budget are 1989 and older. Seems once you hit a 1990 or newer model the price goes way up. I've thought about taking my open trailer, sectioning it(remove the tongue), and attaching the remainder it to my dually. Still use the electric brakes.
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2555367
09/27/18 02:17 AM
09/27/18 02:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I built up this 95 Dodge dually 3500 with a
sleeper on the cab.. this worked great with
my 26' enclosed trailer.. then I changed to
a home built 43' fifth wheel trailer with
living quarters
wave
Re: MOTOR HOME CAR RAMP TRUCK [Re: A/MP] #2555453
09/27/18 11:09 AM
09/27/18 11:09 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Re: MOTOR HOME CAR RAMP TRUCK [Re: DaveRS23] #2555820
09/28/18 02:36 AM
09/28/18 02:36 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have a 99 Jimmy 26 ft box truck, cat diesel, Allison trans (Penske mover) that I'm wanting to convert over to a living quarters to tow my enclosed. The motor home-travel trailer scavenge is what I was thinking. I'll check into what you said, didn't know where to look before, thanks.
Re: MOTOR HOME CAR RAMP TRUCK [Re: cudaman1969] #2555822
09/28/18 02:40 AM
09/28/18 02:40 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
They just listed a Dodge 360 powered ramp truck listed locally on Facebook today in my area. 5500.00
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: MOTOR HOME CAR RAMP TRUCK [Re: pittsburghracer] #2556049
09/28/18 05:21 PM
09/28/18 05:21 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Ahhhhh
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: MOTOR HOME CAR RAMP TRUCK [Re: bigdad] #2556050
09/28/18 05:21 PM
09/28/18 05:21 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
ahhhh,h
Re: MOTOR HOME CAR RAMP TRUCK [Re: bigdad] #2556051
09/28/18 05:25 PM
09/28/18 05:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By bigdad
ahhhh,h
I would use that in a heart beat
Re: MOTOR HOME CAR RAMP TRUCK [Re: cudaman1969] #2556058
09/28/18 05:42 PM
09/28/18 05:42 PM
PA.
"Little"John
"Little"John
PA.
Very nice but I would miss my enclosed trailer to much. I love having all the tools and spare parts that may be needed for a race day. It doesn’t bother some guys to borrow but I hate doing it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
