Sleeved Block. #2555185
09/26/18 08:28 PM
09/26/18 08:28 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
In the past I have searched the topic of sleeving all eight cylinders in an engine block. As usual, the results were all over the board from, no problem I do it all the time, to no way it will never work, and everywhere in between. So I decided to try it for myself. I started with a rusty .060 440 block that was on its way to the scraper. After carefully thinking the job through in my mine I proceeded to sleeve the cylinders. Well today I dyno tested the completed engine, and so far so good. 480 HP at the wheels. No leaks, and no parts on the floor. I can not say how long the block will last. We will find out. With that said. I would not trust this job to just any shop. There is a process to this repair that my not be obvious to everyone.
T & K Performance
Re: Sleeved Block. [Re: ChevyTS] #2555194
09/26/18 08:42 PM
09/26/18 08:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m going to guess it’s best to do one at a time and although I have stayed at a Holiday Inn I’m not the sharpest pencil in the pencil holder
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Sleeved Block. [Re: ChevyTS] #2555195
09/26/18 08:42 PM
09/26/18 08:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know of many guys that do it.. there is
usually a reason to do it.. most have to use
a certain block
wave
Re: Sleeved Block. [Re: MR_P_BODY] #2555234
09/26/18 10:01 PM
09/26/18 10:01 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have seen it done on a couple of numbers matching Ford Cleveland blocks. Bob Book had to do it with several of the R4 blocks he ran as well.
I would imagine it would be best to machine for and fit one or two sleeves at a time. Trying to do all of them or a bank of cylinders all at once, the block would move around too much.
Alan Jones
Re: Sleeved Block. [Re: LA360] #2555235
09/26/18 10:04 PM
09/26/18 10:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Sleeve the entire block one sleeve at a time. When they are all replaced, then bore each to size.
Re: Sleeved Block. [Re: 6PakBee] #2555242
09/26/18 10:20 PM
09/26/18 10:20 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
what about putting it in a furnace and doing a heat treat/normalizing process after installing all the sleeves but befor machining??
Re: Sleeved Block. [Re: ChevyTS] #2555313
09/27/18 12:02 AM
09/27/18 12:02 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
I heard Dirt track guys run all cylinders sleeved. They are aways replacing sleeves because of the dirt getting into cylinders and damaging the cylinder walls. Not sure if this is true.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Sleeved Block. [Re: ChevyTS] #2555319
09/27/18 12:16 AM
09/27/18 12:16 AM
USA
hudsonhornet7x Offline
USA
I have often wondered this. I have a 230 cold weather block that would need several sleeves if not all 8. I have kept it because of the rarity, but I have always been afraid to try.
Re: Sleeved Block. [Re: ChevyTS] #2555321
09/27/18 12:22 AM
09/27/18 12:22 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of interference fit do you go for?
Re: Sleeved Block. [Re: hudsonhornet7x] #2555325
09/27/18 12:32 AM
09/27/18 12:32 AM
PA.
"Little"John
"Little"John
PA.
For the average person paying to have this work done its not worth the money it would cost. move on to better pastures.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sleeved Block. [Re: pittsburghracer] #2555336
09/27/18 12:51 AM
09/27/18 12:51 AM
USA
USA
Thanks John, I know the price would be high, but what kind of power would a sleeved 230 block handle? Would it be better than a regular 230 block?
Re: Sleeved Block. [Re: hudsonhornet7x] #2555343
09/27/18 01:06 AM
09/27/18 01:06 AM
PA.
"Little"John
"Little"John
PA.
No matter what you do to a stock block it’s days are numbered if you crank up the horsepower. I watched Tom Hemphill try every trick in the book to try to get them to last for himself and customers. Tom ended up with a Chevy in his barracuda before he gave up Racing and the guys that wanted to run 8’s or low 9’s switched to aftermarket blocks. Money that has paid big dividends in the long run.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sleeved Block. [Re: pittsburghracer] #2555345
09/27/18 01:19 AM
09/27/18 01:19 AM
USA
USA
Thanks John, I appreciate your no-nonsense answers.
Re: Sleeved Block. [Re: hudsonhornet7x] #2555351
09/27/18 01:33 AM
09/27/18 01:33 AM
PA.
"Little"John
"Little"John
PA.
Lol is that what you call it. I just hate to see people waste money making our sport we love more expensive. I just got belittled over in the general section because I use Harbor Freight digital calipers and said I probably have 10 sets. This same guy gave up Racing many years ago because of expense and probably hasn’t raced since. Trust me I have good mics but they aren’t needed for measuring valve diameter and many other non technical jobs.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sleeved Block. [Re: ChevyTS] #2555371
09/27/18 02:40 AM
09/27/18 02:40 AM
Washington
madscientist Offline
Washington
I've personally set more sleeves that I can count.
It's not tricky it's just sensible machine work. There is not need to stress relive anything or any of that. The press on a sleeve is about .001-.0015 and that's all they need if done correctly.
Leave a decent step for the sleeve to sit on, machine the decks and forget it.
Unless it's a special block it isn't worth it.
If you re trying to make power skip the production block work. By the time you do all the crap to them they ain't as strong as a good aftermarket block and youve pissed away a good bit of money.
I don't use digital calipers or micrometers. But I have 2 sets of pretty damn nice calipers and several sets of shop calipers that I use on the lathe and stuff like that. Those are my beaters. They can be dropped and then I kick them across the shop and throw them away.
The good measuring tools stay in the tool box until I need to do [censored] that needs to be under a couple thou.
I agree with John. You need shop beater tools or you just kill the good stuff banging it around.
Re: Sleeved Block. [Re: madscientist] #2555396
09/27/18 04:47 AM
09/27/18 04:47 AM
Cab_Burge Online work
Cab_Burge  Online Work
I know a lot of NHRA class racers that have had all eight holes sleeved with ductile iron sleeves to make more power and to seal better work shruggy
I agree on buying a better block on a all out drag race motor but when that is not a option you have to punt shruggy work
Re: Sleeved Block. [Re: ChevyTS] #2555429
09/27/18 10:18 AM
09/27/18 10:18 AM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
There is an earlier thread on this subject in which Ray Barton gives the procedure they follow when they sleeve and entire block.
He has no problem doing this.
Good enough for him, good enough for me.
I have an R3 block that came with a bore too large for the class I wanted to run. It has eight sleeves and makes a little over 2HP per CI with no problems yet.
Re: Sleeved Block. [Re: Cab_Burge] #2555432
09/27/18 10:25 AM
09/27/18 10:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 4 or so Harbor Freight calipers for
everyday use(a few 6" and 1 12" calipers.. I
use the 12" ones for measuring push rod lengths)
then I have my nice stuff for engine work
wave
Re: Sleeved Block. [Re: MR_P_BODY] #2555479
09/27/18 11:50 AM
09/27/18 11:50 AM
moparx Offline
moparx  Offline
i have a couple junk fowler dial calipers, one without a dial lens, i use for general dirty work, and scribing. [do NOT use calipers for scribing ! it screws up the tips !] they don't always repeat, or zero out, but are within .003-.005.
my good tools are in the box, protected, until precision work is called for. hobo freight calipers are fine for general dinking around.
john, if you are like me, you NEED a bunch of those things, because i forget where i lay them down. if you got a bunch, just get one of the others. biggrin
beer
Re: Sleeved Block. [Re: moparx] #2555513
09/27/18 01:07 PM
09/27/18 01:07 PM
PA.
"Little"John
"Little"John
PA.
Exactly. When you have different work areas and jobs the price is right. I even have some at my head porting area that I have ground on so they fit in tight areas. These stay in this area because they are usually aluminum covered. Harbor Freight snap gauges also come in handy but please don’t tell anyone. Lol 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
