Mounting "DART" fender badges? #2554801
09/25/18 11:27 PM
09/25/18 11:27 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
Just wondering what kind of fastener should be used on the plastic studs of the '72 "DART" front fender badges. I don't want to break those expen$ive pieces, and they don't look like trim adhesive was the intended mounting method. Is it a self-tapping nut of some kind?
thanks.
Re: Mounting "DART" fender badges? [Re: DrCharles] #2554927
09/26/18 09:54 AM
09/26/18 09:54 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes, a tin self tapping nut.
JB Rhinehart, Realist
A-Body's RULE!
Re: Mounting "DART" fender badges? [Re: DrCharles] #2554944
09/26/18 11:01 AM
09/26/18 11:01 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Called "speed nuts".
Re: Mounting "DART" fender badges? [Re: Pntastar69] #2554960
09/26/18 11:33 AM
09/26/18 11:33 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have some Swinger emblems and they have a push-on plastic/rubber sleeve on the studs instead of a spin on nut. Kinda like heat shrink tubing.
Re: Mounting "DART" fender badges? [Re: Neil] #2555017
09/26/18 01:32 PM
09/26/18 01:32 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If you buy aftermarket emblems it comes with that stuff. I can tell you from experience they don't last long on a car... tsk
A-Body's RULE!
Re: Mounting "DART" fender badges? [Re: Rhinodart] #2555043
09/26/18 02:38 PM
09/26/18 02:38 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
One emblem I have is NOS and it has a couple of those rubber sleeves and they are hard as a rock. They'll have to be to cut them off with an x-acto knife.
The spin on nuts are better. Don't use the push-in inserts that go in from the outside. Major pain and can chip the paint if your not careful.
Re: Mounting "DART" fender badges? [Re: DrCharles] #2555073
09/26/18 03:50 PM
09/26/18 03:50 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Push-in retainers are called barrel clips; they make nameplate removal easier but you have to size them correctly and they can be tricky to install.
The stamped thread-cutting nuts are fine if you can get to them on the backside.
Re: Mounting "DART" fender badges? [Re: topside] #2555099
09/26/18 04:51 PM
09/26/18 04:51 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I tried installed some Mustang emblems with the push-in clips and because the clear coat had filled the holes in too much they would not fit right. I should have filed the holes open with a jeweler's rat tail file, but didn't.
Re: Mounting "DART" fender badges? [Re: DrCharles] #2555239
09/26/18 10:16 PM
09/26/18 10:16 PM
West Plains, MO
West Plains, MO
Thanks! Is there a particular size of speed nut that works best?
Also, one of my "DART"s is broken in half (between the DA and RT). Its pins have a very hard, yellowish plastic tube. I assume that's the "barrel clip" referred to above. And maybe why a previous owner broke it, too. Any way to fix that, such as soldering?
Re: Mounting "DART" fender badges? [Re: DrCharles] #2555322
09/27/18 12:22 AM
09/27/18 12:22 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think the plastic sleeves go on from behind like a nut would only they push on.
The other type of retainers that I had trouble with are like a funnel that go in the holes in the car and then the emblem pins go inside them afterwards. It's all supposed to fit nice and snug, but the hole sizes have to be right on or they don't work right.
You'll have to measure the studs and buy the nuts that are the right size. Ebay is full of them.
If your Dart emblem is broke just buy a new one. I think they are made of die cast pot metal?
Re: Mounting "DART" fender badges? [Re: Neil] #2555337
09/27/18 12:52 AM
09/27/18 12:52 AM
West Plains, MO
West Plains, MO
Yeah... $63 worth of pot metal! whistling
Re: Mounting "DART" fender badges? [Re: DrCharles] #2555348
09/27/18 01:25 AM
09/27/18 01:25 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Too much.
I checked Mancini and they have them for $36 and change.
Re: Mounting "DART" fender badges? [Re: DrCharles] #2555352
09/27/18 01:35 AM
09/27/18 01:35 AM
West Plains, MO
West Plains, MO
Thanks... didn't think to look there. $36.95 plus their "unable to determine shipping before processing order" might be more reasonable.
