426 Stroker, is it OK to supercharge?
#2555022
09/26/18 01:50 PM
09/26/18 01:50 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Manley makes a nice 426 stroker kit for the Gen III engine. If you put one into a BGE block with a positive displacement supercharger ( IE Hellcat), would that make a nice combination? Or would side loading of the cylinders, lack of crank overlap, etc be a detriment to supercharging?
Thank you
Re: 426 Stroker, is it OK to supercharge?
[Re: hudsonhornet7x]
#2556228
09/29/18 11:55 AM
09/29/18 11:55 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
FC lowered the stroke on the Hellcat so they could get a 1.28 comp Ht more material above the pin so they didn't have to go high end after market for the piston, Both the SRT392 and the Hellcat use the same length rod(6.20)
A BGE based 426CI stock 4.09 bore and 4.05 stroke with a 6.125 rod(1.51RR) use a 1.12 comp Ht piston, Arrington, Muscle Motors Xtreme, Seidle Motorsports, and a few others offer this combo for boost applications...soooooooooooo it must be working. I'm redoing a Arrington alum block 440 ,4.16 X 4.05 ,6.125 rod 1.09 Comp Ht , Ken Bell supercharger ,after 30K miles @ 10 psi #3 cylinder sleeve split. Just bought a 426CI based 6.1 short block (4.08X4.08) 6.125 Rod 1.88 Honda journal .866 Dia pin ,had 1.065 Comp Ht JE's everything that every one says not to do .. they did and ran 18psi with a Whipple 2.9L supercharger...since April 2016, 22kmiles on it...split the bore in #1 up at Beaver spring this past May....if you want longevity..this is not your combo, I bought it to see if I can use Darton sleeve Mopar part # P4510316 This past spring we did a BGE based 427CI , 4.125 X 4 with a 6.125 rod a 1.14 comp ht(1.53RR) 4.5L whipple...cracked the Hellcat head...short block was fine... With todays metallurgy 1.09 Comp ht(1.5 RR) is about the lowest you should go and survive with low boost (6-12) anything higher you should aim for a minimum of 1.12 comp ht.
There are quite a few 03-08 5.7 based "392" pushing 14-18psi with a 4.05 crank,6.125 rods and 1.09 Comp ht, granted it's a 3.917-3.957 piston, smaller surface area, so it'll handle the pressure better than a 4.09
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: fbs63]
#2556293
09/29/18 03:18 PM
09/29/18 03:18 PM
ric3xrt
Trumbauersville PA
My personal opinion is the early 5.7 is the best choice for boost. Thick cylinder walls and a smaller bore. Better for complete ignition of the boosted mixture. Top Fuel motors are 4.310 x 4.500. There's a reason they run the small bore. Before the BGE/Hellcat block, I would agree 100%, leave the 6.1s and SRT392 blocks to the NA crowd. Now A budget build lower RPM 400CI and under, your a head of the game if you use the older 5.7 block.....you have a better chance of liftting the heads before you hurt the older block...with good internals. Higher RPM Short stroke build 380-410Ci the BGE would be a great block to use , look at the power the Hellcat/Demons are making. 3.9-4.00 inch bores are what a lot auto manufactures are using and have gone to , it's a better bore size to keep emissions down. Interesting point about the Top Fuel , Bore/stroke ratio equals .957, Bore stroke ratio for the 5.7 based "392" 4.05 crank is .967 and 4.08 is .957, to get that with a stock 4.09 BGE/Hellcat you need a 4.25 crank(.962) need a 6 inch rod to get a 1.14(1.15 zero deck dry) Comp Ht, and 6.07 length rod gets you a 1.08ish..but both are horrible Rod ratios
#2556306
09/29/18 03:51 PM
09/29/18 03:51 PM
Posts: 1,541 USA
hudsonhornet7x
USA
I appreciate all the back and forth on this subject, engine math and theories are fascinating.
Our decision has been made. We will be going with a stock stroke Hellcat crank. BGE block, and Manley rods with Diamond pistons and H-13 wristpins. THe block will also get ARP studs and a line hone along with all other necessary machining to make everything square.
A2 Speed is building it and claims that this short block will more than handle the heads and blower we have.
Thank you all again.
