Re: When is the bigger U joint needed?
[Re: radar]
#2554844
09/26/18 12:28 AM
09/26/18 12:28 AM
Posts: 4,457 Washington
madscientist
Washington
I can't see reason to use less than a 7290 joint and if you are spending the money why not a 1350?
You can't hurt yourself with a bigger joint in joint.
[Re: AndyF]
#2554859
09/26/18 12:59 AM
09/26/18 12:59 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I always use 1350 u joints. Never bothered to test different u-joints, I just automatically use the 1350 in every build. It seems to be the industry standard these days. Yep. Do it once, do it right
[Re: B3422W5]
#2554883
09/26/18 01:57 AM
09/26/18 01:57 AM
Posts: 4,700 Wichita
GY3
Wichita
I tried using 7260 and 7290 joints. It was a no-go in my combo. I even destroyed a FRONT yoke after a u-joint broke on the starting line at the dragstrip. 1350 Strange shaft and u-bolt rear yoke solved my issues. I even added 150 HP and zero issues.
[Re: radar]
#2554916
09/26/18 08:55 AM
09/26/18 08:55 AM
Posts: 570 UK
rb446
UK
Put a big yoke on it, a friend here has just broke his front U at the track as its starting to hook...its only a mild 440 around 360hp/450TQ, 3700lb roadrunner on Dot drag tyres, 727- stockish verter....he's going Big.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: radar]
#2554940
09/26/18 10:37 AM
09/26/18 10:37 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Go big. I started breaking the factory driveline stuff in my cuda running mid 11s at 3700 lbs. Go big once and be done w/ it.
[Re: radar]
#2554967
09/26/18 11:51 AM
09/26/18 11:51 AM
B3422W5
Portage,michigan
D’oh I called him and he said he already put a small U end on my driveshaft instead of the conversion U. No big deal it’s just a shortened old truck driveshaft. I’m going to run a loop anyway so we’ll see how long it lasts. If or when I crack it I will throw the big yoke on my pinion.
Thanks Rdr The tranny will need looked at if you break the driveshaft. Keep that in mind
[Re: radar]
#2555070
09/26/18 03:43 PM
09/26/18 03:43 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Good 1350s, if you can get a 1350 yoke for the rear. Why a 9.25? Given enough horsepower/weight/radials/sticky track, forged slip yokes will break too. A good billet piece will take care of that.
[Re: radar]
#2555342
09/27/18 01:04 AM
09/27/18 01:04 AM
Posts: 1,682 Philadelphia
radar
Philadelphia
I wanted to do a 9.25 to be different and to be a cheapskate. I did yukon axles, crush sleeve eliminator kit, bearings, seals, and got everything back in spec for small money amd the axle was a parts trade. (Actually went through 2 to find a good one) I’m hoping street tires mixed with a light rear end in a 3000lb pickup truck will make traction always be the weakest link in my driveline. I was actually considering running an 8.25 because I have three of them but they look like a toy next to the 9.25. I did spend a few bucks on bling and bought a cast B&m finned cover which looks really nice under there.
Oh and a 70’s ramcharger 9.25 is already set up for 5 on 4.5” bolt battern and came in a width that fits perfectly in my tubs with my wheels. My ZJ rear disc brake system bolted right up too with just an enlargement of the central pilot hole which is another plus.
So no drag radials, no heavy weight, no track, and just a stock yoke... wish me luck, “hold my beer” haha
[Re: radar]
#2555353
09/27/18 01:36 AM
09/27/18 01:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran the small u-joint and yoke with the stock little straps and bolts on my racecar till I blew the ring gear on my stock 8 3/4.. once it blew the ring I changed over to a alum center 8 3/4 with a 1350 u-joint.. its still running fine but the car is for sale now
