Page 2 of 3 1 2 3
Re: Dyno guess 440 stroker - my A12 upgrade [Re: GomangoCuda] #2554106
09/24/18 03:32 PM
09/24/18 03:32 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By GomangoCuda
Originally Posted By jbc426
Great results! I was surprised to see the size of the outboard main jets. Those are 10 sizes larger than what my 493 with similar sized cam & Indy EZ's likes according to my wideband. I do run the mechanical DC Holley's.
I bet his are .089" and .091" holes in metering plates. That would be about the same as your jet sizes in metering blocks. Decades ago when I raced with the mechanical carbs at least 4 times a week I had three outer metering blocks with 78, 80,and 82 jets. I could swap them at the track a lot quicker than switching jets. Usually ran 78's and 80's on warm days and 80's and 82's on cold days. 64's or 65's in the center.
I don't know if its the the nature of the 6 pack or just a coincidence, but no matter what I run it on, I'll start with 65 center and 80's outsides. Then when I'm all done I'm usually exactly what you describe, 64/65, and 77/82, and does not seem to matter much if its a 350 hp or 550 hp deal. shruggy
Re: Dyno guess 440 stroker - my A12 upgrade [Re: BSB67] #2554207
09/24/18 08:18 PM
09/24/18 08:18 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Itll all be different when the lid goes on top of the carbs .
. Might be able to jet down
And itll all be different when on the street
We were tuning to get rid of the slight lean at about
3500-4500 when the outboards kicked in .
The fuel urve evened right out . With thicker springs
and fatter jets.
It might be way off for the road ..
Re: Dyno guess 440 stroker - my A12 upgrade [Re: BSB67] #2554212
09/24/18 08:22 PM
09/24/18 08:22 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
We had perfect air
O89 and 91 resemble stock plates
Started there ..
77/82 seems small ..
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2554350
09/25/18 03:20 AM
09/25/18 03:20 AM
My pump gas six pack 511 C.I. low deck stroker motor liked .094 fuel inlet size on the driver side outboard plates with .096 on the driver side of the Eddy aluminum dual plane six pack intake using a set of OEM 1970 440 California automatic carbs. modded by C&J Engr. in Whitter, CA up
I don't remember those List numbers now though blush
I had that motor on two different engine dynos and it made peak HP at either 5500 RPM or 5600 RPM with peak torque at 4500 or 4600 RPM . I tested three different sets of carbs on the first test session, That set of modified 1970 carbs., a new set of OEM 1971 440 replacement carbs down and a set of the original mechanical carbs as well as several different air cleaner elements as well as stacking two elements on top of each other.
That motor made the most HP and torque with the air cleaner base on and no air cleaner element with the mechanical carbs. There was only 7 HP differences between all three sets of carbs though shock shruggy
Re: Dyno guess 440 stroker - my A12 upgrade [Re: GomangoCuda] #2554462
09/25/18 01:25 PM
09/25/18 01:25 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Wow, great info you guys! This was back in the day before the non-stick gaskets, nylon bowl washers and widebands too, right?
The Holley jets are not super accurate either. Does anyone make blueprinted Holley jets that actually match the flow of the number stamped on them?
I don't have a heat crossover in my Indy's, have insulating mat between the intake manifold and valley pan and run a Shaker hood. The carbs are still super sensitive to air temperature and heat soak. I can feel significant power loss as heat saturates the intake from heat soak.
I wonder if the same power loss would occur with multi-point EFI?
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2554831
09/25/18 11:59 PM
09/25/18 11:59 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Do mind sharing the cam card? That’s a bad dude!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Dyno guess 440 stroker - my A12 upgrade [Re: 68 HEMI GTS] #2554912
09/26/18 08:18 AM
09/26/18 08:18 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
No sense of hiding it
Hopefully it can get some critique here
But its tough to compare to a reg solid cam spec
due to the roller part of it . I think - i dont know much about
reading split cam cards and All of the logic behind
it .. and ill effects of this and that .. I guess well just call it the FM cam.
Dont know how , but it works .. lol.
Hopeful its nice on street - it sure idles like
my old bobk cam.
I only got 10-12” of vacuum
But i wasnt tuning for vacuum yet ..
Hopeful i can get it higher with a couple screws .
Some more tweaking coming
I got an H pipe and factory manifolds mounted
On Dyno last night ..
Figures the h pipe was contorted
Needed a bunch of fat guys and a bigass pipe to
twist the collector flange into position ..
But moving along
Will be bad air tonight frown
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2554921
09/26/18 09:24 AM
09/26/18 09:24 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Looks like your cam guy has done this before.
Re: Dyno guess 440 stroker - my A12 upgrade [Re: BSB67] #2554924
09/26/18 09:46 AM
09/26/18 09:46 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
It wasnt summit tech support thats for sure
I think the builders had some input , and seem to have a good
relationship with comp.
Even though theyre Not normally MP guys, lol , theyre anal as
heck and have a couple beefy mopars under
their belt . Everything they touch seems to sing pretty well.
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2554979
09/26/18 12:18 PM
09/26/18 12:18 PM
sweden
carter Online content
carter  Online Content
sweden
Why can I not see a cam card, just see a "empty frame"?
Re: Dyno guess 440 stroker - my A12 upgrade [Re: carter] #2555253
09/26/18 10:37 PM
09/26/18 10:37 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Well it worked pretty good with the Headers but did not like the cast manifolds and 2 1/2 inch exhaust
Re: Dyno guess 440 stroker - my A12 upgrade [Re: carter] #2555261
09/26/18 10:46 PM
09/26/18 10:46 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
shruggy works fine for me.
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2555297
09/26/18 11:30 PM
09/26/18 11:30 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Well how bad was it?
Getting old just means you were smarter than some and luckier than others.
Re: Dyno guess 440 stroker - my A12 upgrade [Re: dannysbee] #2555401
09/27/18 07:56 AM
09/27/18 07:56 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Some more tuning could have been had , but three jet
Sizes later , two different sets of mufflers and ..........
We jetted all the way down to 81/83’s and 64’s on center
We lost about 90 hp .. from headers to manifolds And
2 1/2” exhaust with h pipe ..
And .......
We gained torque and about 10 hp with big a12 air cleaner and kn air filter
Since we have trickflows
The car is gonna go together with headers
It will not even try to appear stock frown
And thats ok ..
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2555404
09/27/18 08:06 AM
09/27/18 08:06 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I was the assistant
20 HP by adding the air breather
The engine did not like the ex manifolds at all
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2555434
09/27/18 10:34 AM
09/27/18 10:34 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Yes it's a trade off for certain. But 550-570 is nothing to sneeze at. Anything faster than a 11.50 requires a roll bar. I think a drive anywhere stock appearing automatic a12 with a 3.54 gear that would run 11.50's through the mufflers would be awesome.
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2555469
09/27/18 11:34 AM
09/27/18 11:34 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sounds like the headers are an extremely cost effective power upgrade on that combo.
They never do.
Some just dislike them more than others.
650hp in a 4000lb car should be able to run 10.60’s at 124+.
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2555494
09/27/18 12:10 PM
09/27/18 12:10 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
That's awesome power from a relatively mild combination. I just picked up some Tricklow 240s myself so it's cool to see how much power they are capable of. Hard to not use headers when there is that much power left on the table without them...
2 kids and a dog
Re: Dyno guess 440 stroker - my A12 upgrade [Re: TonyS451] #2555699
09/27/18 09:20 PM
09/27/18 09:20 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Curious if different six packs base plates would create different result
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2555731
09/27/18 10:33 PM
09/27/18 10:33 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Guess were doin it again with headers and hemi muffs .
And baseblate / air cleaner . And black springs
Lookin for 690 ...
still cant believe we gained with Baseplate . Lol
Page 2 of 3 1 2 3
