Upper radiator hose with or without A/C difference? #2554628
09/25/18 06:15 PM
09/25/18 06:15 PM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
I'm looking to buy an upper radiator hose. The listings have with or without A/C. Is there a length difference there? I don't have A/C system installed but will in the future.
Re: Upper radiator hose with or without A/C difference? [Re: ksat] #2554630
09/25/18 06:19 PM
09/25/18 06:19 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Most A/C upper hoses are longer, have 1 or 2 more curves and end up on either side of the radiator.
Non A/C-hoses are usually hoses with a fairly simple 90 bend ending up near the center of the radiator.
Re: Upper radiator hose with or without A/C difference? [Re: ksat] #2554638
09/25/18 06:28 PM
09/25/18 06:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The with AC hose is shaped to clear the compressor.
Don't be the exception.
Re: Upper radiator hose with or without A/C difference? [Re: ksat] #2556828
09/30/18 11:50 PM
09/30/18 11:50 PM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
What car and engine are you asking about?
Re: Upper radiator hose with or without A/C difference? [Re: ksat] #2556858
10/01/18 01:12 AM
10/01/18 01:12 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
often the with A/C version is 1 hose size larger at the radiator end.
