Carb switch or not...
#2554541
09/25/18 04:09 PM
09/25/18 04:09 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Question for you guys. Ive purchased a set of Trick flow 240 heads for my 505. The heads will replace stock stealth heads, and for now ive decided to stick with the current mild hydrualic flat tappet cam (Comp XE284, 240 @.050, .507 lift, 110lsa). The current intake is a Edelbrock Torker 11 and carb is Quick fuel super street 830 mech secondaries. My question is do you think there will be any benefit worth ponying up for a 950 quick fuel carb? The 830 carb is like brand new and should be easy enough to flip, so I'm not really concerned with the $$. Just want the carb thats going to make the most power and also be street friendly . Its also has TTI 1 7/8 headers, 3" exhaust and a 4 speed with 3.55's. Its a mostly street driven 72 Challenger. Thanks for your feedback
2 kids and a dog
Re: Carb switch or not...
[Re: TonyS451]
#2554554
09/25/18 04:22 PM
09/25/18 04:22 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I had that S/S carb on the 360 that was in my Dart when i bought it, but the 750 version, not the 830. Ran it at the track, worked well. Swapped it for a trick 950 carb that i had laying around that was on an engine masters entry. The 950 was just hair more than a tenth better on the same night at the track. Hope this gives a little perspective. Car runs whats in my signature
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2554560
09/25/18 04:29 PM
09/25/18 04:29 PM
TonyS451
Chicago, IL
I had that S/S carb on the 360 that was in my Dart when i bought it, but the 750 version, not the 830. Ran it at the track, worked well. Swapped it for a trick 950 carb that i had laying around that was on an engine masters entry. The 950 was just hair more than a tenth better on the same night at the track. Hope this gives a little perspective. Car runs whats in my signature Thats great info. Obviously, different combo but gaining a tenth in back to back test is pretty cool.
2 kids and a dog
[Re: krautrock]
#2554570
09/25/18 04:44 PM
09/25/18 04:44 PM
TonyS451
Chicago, IL
I'll have to look. The model I have is the ss 830, so according to your chart it should. Thanks for the link
2 kids and a dog
[Re: lewtot184]
#2554644
09/25/18 06:33 PM
09/25/18 06:33 PM
TonyS451
Chicago, IL
the states 1.45/1.56 venturi's 1.75 throttle bores for the 830. the 830 looks good to me. Thats what i was thinking. Good to have the facts. Not the first time I've heard of a "smaller" carb actually being as big or bigger than the "bigger carb".
2 kids and a dog
[Re: AndyF]
#2554646
09/25/18 06:35 PM
09/25/18 06:35 PM
TonyS451
Chicago, IL
Too bad you don't live next door to BradH. You could try a different carb every week for several months and still not reach the back of his carb shelf. Hey, the guy likes carbs
2 kids and a dog
[Re: fast68plymouth]
#2554652
09/25/18 06:38 PM
09/25/18 06:38 PM
TonyS451
Chicago, IL
I’d just try it before I bought another carb. probably for the best
2 kids and a dog
[Re: AndyF]
#2554657
09/25/18 06:48 PM
09/25/18 06:48 PM
BradH
Too bad you don't live next door to BradH. You could try a different carb every week for several months and still not reach the back of his carb shelf. Factually incorrect: I count only 6, i.e. 1.5 months worth at 1 per week. But I get your point.
[Re: BradH]
#2554676
09/25/18 07:17 PM
09/25/18 07:17 PM
Posts: 31,050 Oregon
AndyF
Too bad you don't live next door to BradH. You could try a different carb every week for several months and still not reach the back of his carb shelf. Factually incorrect: I count only 6, i.e. 1.5 months worth at 1 per week. But I get your point. You could build a big V12 and use all six of those carbs at the same time. Then you wouldn't have any extras.
[Re: TonyS451]
#2554682
09/25/18 07:29 PM
09/25/18 07:29 PM
Posts: 3,916 usa
lewtot184
usa
the states 1.45/1.56 venturi's 1.75 throttle bores for the 830. the 830 looks good to me. Thats what i was thinking. Good to have the facts. Not the first time I've heard of a "smaller" carb actually being as big or bigger than the "bigger carb". i'd just run it. I think it's close to the ideal size for a single plane; especially if you drive it. if it's race only i'd try symmetrical venturi and throttle bores (850) with a single plane.
[Re: BradH]
#2554687
09/25/18 07:35 PM
09/25/18 07:35 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Too bad you don't live next door to BradH. You could try a different carb every week for several months and still not reach the back of his carb shelf. Factually incorrect: I count only 6, i.e. 1.5 months worth at 1 per week. But I get your point. Seems like they should be in a glass case with a red velvet rope strung through some big brass stands.
[Re: BradH]
#2554723
09/25/18 09:05 PM
09/25/18 09:05 PM
Posts: 4,457 Washington
madscientist
Washington
Too bad you don't live next door to BradH. You could try a different carb every week for several months and still not reach the back of his carb shelf. Factually incorrect: I count only 6, i.e. 1.5 months worth at 1 per week. But I get your point. It may be factually incorrect but it damn sure made me LOL.
#2554820
09/25/18 11:44 PM
09/25/18 11:44 PM
BradH
Too bad you don't live next door to BradH. You could try a different carb every week for several months and still not reach the back of his carb shelf. Factually incorrect: I count only 6, i.e. 1.5 months worth at 1 per week. But I get your point. Seems like they should be in a glass case with a red velvet rope strung through some big brass stands. I was saving up to have each one titanium nitride coated first. Until then, recyclable plastic grocery bags covering each carb will have to suffice.
