Re: Steering parts
[Re: 70charger512]
#2554299
09/25/18 12:15 AM
09/25/18 12:15 AM
Posts: 36,039 Lincoln Nebraska
RapidRobert
pitman arm/idler arm/(2) tie rod sleeves/(4) tie rod ends/right & left torsion bars of a recommended diameter for your app. EDIT on the tie rod ends, 2 lefties/2 righties. MORE EDIT center drag link
Re: Steering parts
[Re: 70charger512]
#2554368
09/25/18 09:18 AM
09/25/18 09:18 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I would not bet on a reproduction anything being better than OEM just because it's a reproduction.
Lot's of crap out there.
Re: Steering parts
[Re: Supercuda]
#2554602
09/25/18 05:40 PM
09/25/18 05:40 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Lot's of crap out there. Well of course, but i mean it has to be a good product, which would have better handling/steering.
Re: Steering parts
[Re: RapidRobert]
#2554608
09/25/18 05:52 PM
09/25/18 05:52 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
pitman arm/idler arm/(2) tie rod sleeves/(4) tie rod ends/right & left torsion bars of a recommended diameter for your app. EDIT on the tie rod ends, 2 lefties/2 righties. MORE EDIT center drag link So with pitman arms, tie rod ends, torsion bars, and center drag link i can build a full steering system? (From the steering box down and i already have a k member) Would sway bars also be a good idea? Are they necessary?
Re: Steering parts
[Re: 70charger512]
#2554957
09/26/18 11:31 AM
09/26/18 11:31 AM
RapidRobert
If nothing has been altered/welded/added that would interfere with the returning to the OE steering items mentioned then no problemo. Sway bars are good/recommended but there may or may not be interference issues. I would suggest getting it back to normal & have an up & running machine then check into a sway bar (type/dia/fitment etc) for your app. As you know the pitman arm bolts onto the st box splines/idler fits in the slot in the kmember/center link is by itself & the tie rod ends/sleeves on each end of the center link just drop into the tapered holes in the "arms" of the left/right lower ball joints. You would get the st box halfway between lock to lock & adj the sleeves so the tires are pointed straight ahead (that'd be a start).
