Page 1 of 3 1 2 3
Dyno guess 440 stroker - my A12 upgrade #2553328
09/22/18 07:03 PM
09/22/18 07:03 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Broke in today on dyno
Goin for pulls tomorrow
4250 eagle crank
7.1 rods
70 over diamonds
9.5:1 compression
240 trick flows
Sick pack intake
Tti 1 7/8
6 pack
Firecore wires / dizzy
custom mild comp cam
600 lift
Split duration
Hydraulic rollers
1.5 hs rockers
Any Guesses
Losses through stock manifolds Monday or Tuesday
Re: Dyno guess 440 stroker [Re: sogtx] #2553331
09/22/18 07:20 PM
09/22/18 07:20 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
559 hp
Re: Dyno guess 440 stroker [Re: CSK] #2553336
09/22/18 07:29 PM
09/22/18 07:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Did I read that right. .070 over 440 block.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dyno guess 440 stroker [Re: pittsburghracer] #2553345
09/22/18 07:57 PM
09/22/18 07:57 PM
IN
ahy Offline
ahy  Offline
IN
605 HP, 650 TQ (with headers). I don't think it will like the manifolds.
Re: Dyno guess 440 stroker [Re: pittsburghracer] #2553348
09/22/18 08:12 PM
09/22/18 08:12 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Lol sleeved
Re: Dyno guess 440 stroker [Re: sogtx] #2553393
09/22/18 10:41 PM
09/22/18 10:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Need real/complete cam specs.
My guess is, it will make peak power right before the valvetrain gets unhappy, unless the duration is really short.
Re: Dyno guess 440 stroker [Re: sogtx] #2553407
09/22/18 11:11 PM
09/22/18 11:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Between 525 and 650 HP, depending on the cam.
Re: Dyno guess 440 stroker [Re: BSB67] #2553432
09/23/18 12:15 AM
09/23/18 12:15 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
You took my guess
smile
With headers it should make easy 575-600 with almost any mild performance cam
2 kids and a dog
Re: Dyno guess 440 stroker [Re: sogtx] #2553496
09/23/18 03:53 AM
09/23/18 03:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
With the exh manifolds about 525 to 550. Good luck , Ron
Re: Dyno guess 440 stroker [Re: 383man] #2553570
09/23/18 12:07 PM
09/23/18 12:07 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
First pull resulted in poor attachment to dyno
frown
Fabricating new mounts ..
may have been tractor supply grade 8
Constantly learning
and regaining common sense . Lol
Re: Dyno guess 440 stroker [Re: sogtx] #2553591
09/23/18 12:52 PM
09/23/18 12:52 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
A fat bar with a couple of holes going to the lug on the right above your mount might help. That would tiie your mount to a second lug.
Getting old just means you were smarter than some and luckier than others.
Re: Dyno guess 440 stroker [Re: sogtx] #2553614
09/23/18 01:42 PM
09/23/18 01:42 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
New mounts fabbed
Uncorrected hp 672
Centers 65
Outboards 89/91 staggered
Time to play with jetting and timing and
Secondary springs
Lean in middle due to six pack bog
Rejetting to 92/94
Keeping timing at 35
Wish i could poke holes in my nice ttis and do individual
EGTs to see if staggered jetting is valid .
I think we got a monster on 90 pump fuel .
Great guys workin with me .. takin a break and
Rejetting .
Re: Dyno guess 440 stroker [Re: sogtx] #2553621
09/23/18 01:53 PM
09/23/18 01:53 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Watching the outboards open and suckin in 55
degree air is cool .
Stll got 1500 rpm and plenty of adjustments to go
Re: Dyno guess 440 stroker [Re: sogtx] #2553674
09/23/18 04:04 PM
09/23/18 04:04 PM
warren, mich.
dwayne welder Offline
warren, mich.
Install aircleaner set up?????
Re: Dyno guess 440 stroker [Re: sogtx] #2553804
09/23/18 08:08 PM
09/23/18 08:08 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
got a chance to talk to dave dudek yesterday at the NMCA race at indy and he showed me a chassis dyno sheet of 699hp at the wheels. i'm impressed about what guys are doing with these old '60's engines.
Re: Dyno guess 440 stroker [Re: lewtot184] #2553815
09/23/18 08:34 PM
09/23/18 08:34 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Well im cheating a little with the trickflows
Regardless
Air cleaner , great idea
Then were doin cast manifolds
With 2 1/2 h pipe .
Did good at 66o hp corrected
Then the builder wants to try 850 quickfuel on
performer intake .
Re: Dyno guess 440 stroker [Re: sogtx] #2553821
09/23/18 08:47 PM
09/23/18 08:47 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Performer or Performer RPM ?
Will bee interesting to see the difference with HP Manifolds
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Dyno guess 440 stroker [Re: sogtx] #2554035
09/24/18 12:27 PM
09/24/18 12:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Very nice. You know you've got nice testing conditions when corrected numbers are lower than actual.
Was the intake manifold modified?
Re: Dyno guess 440 stroker - my A12 upgrade [Re: sogtx] #2554055
09/24/18 12:59 PM
09/24/18 12:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Great results! I was surprised to see the size of the outboard main jets. Those are 10 sizes larger than what my 493 with similar sized cam & Indy EZ's likes according to my wideband. I do run the mechanical DC Holley's.
Re: Dyno guess 440 stroker - my A12 upgrade [Re: jbc426] #2554069
09/24/18 01:46 PM
09/24/18 01:46 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I bet his are .089" and .091" holes in metering plates. That would be about the same as your jet sizes in metering blocks. Decades ago when I raced with the mechanical carbs at least 4 times a week I had three outer metering blocks with 78, 80,and 82 jets. I could swap them at the track a lot quicker than switching jets. Usually ran 78's and 80's on warm days and 80's and 82's on cold days. 64's or 65's in the center.
Page 1 of 3 1 2 3
