Re: BB AMD valve cover fitment issues
[Re: JoesMopar]
#2554027
09/24/18 12:03 PM
09/24/18 12:03 PM
fast68plymouth
So. Burlington, Vt.
Stock valve covers are made for stock heads....... which have the bolt holes/studs not perpendicular to the v/c rail, using gaskets that are fairly compliant so they seal against irregular surfaces.
My guess is those v/c’s would work just fine on a set of 906’s with some cork gaskets.
