Rocker shaft orientation #2553922
09/24/18 12:44 AM
09/24/18 12:44 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
notch up, down, facing front, back?
Re: Rocker shaft orientation [Re: MattW] #2554226
09/24/18 08:50 PM
09/24/18 08:50 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So after a little detective work this is what I came up with.
Notch up for intake shaft and exhaust shaft.
you want oiling holes to face the spark plugs
Re: Rocker shaft orientation [Re: MattW] #2554326
09/25/18 01:26 AM
09/25/18 01:26 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Thanks for coming back with that
"Just a Bracket car dressed up like a streetcar"
Re: Rocker shaft orientation [Re: Just-a-dart] #2555150
09/26/18 07:00 PM
09/26/18 07:00 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Fix my previous post.
Both notches are to be facing up.
Re: Rocker shaft orientation [Re: MattW] #2555215
09/26/18 09:29 PM
09/26/18 09:29 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Welp, I have no idea where mine are at when I assembled the motor. I didn't know it mattered!
Is this called out in the manual anywhere?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Rocker shaft orientation [Re: MattW] #2555216
09/26/18 09:32 PM
09/26/18 09:32 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Fwiw, there is no mention of this notch in the factory service manual.
2020 RAM 1500
Re: Rocker shaft orientation [Re: GoodysGotaCuda] #2555878
09/28/18 10:00 AM
09/28/18 10:00 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I've LOOKED high and low.
Nothing on orientation.
The picture is from a 5.7 pre 06.
I also have factory replacement rockers shaft and it was assembled the same way.
Factory service manual shows how to install them when replacing them as a unit.
I have a picture of them but the file is too big on my phone. Need to resize them and I'll post it.
Matt
Re: Rocker shaft orientation [Re: MattW] #2555964
09/28/18 01:33 PM
09/28/18 01:33 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
2
Re: Rocker shaft orientation [Re: MattW] #2555974
09/28/18 01:52 PM
09/28/18 01:52 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I always left the bolts in mine when removed, so I never paid attention to this. But the set I have off 1 I have apart now, all notches up.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Rocker shaft orientation [Re: MattW] #2556198
09/29/18 09:25 AM
09/29/18 09:25 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'd say about 95% of the OEM engines I've pulled apart in the last 3 years the notches were up, there a have been a few early 5.7s that there was no rhyme or reason to up or down. the notch should be up.
Re: Rocker shaft orientation [Re: ric3xrt] #2556285
09/29/18 02:37 PM
09/29/18 02:37 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Notches up but also oil holes pointed to the inside.
If you mix up the shafts you could end up with an intake shaft on an exhaust side with the oil holes pointed outwards.
Matt
Re: Rocker shaft orientation [Re: MattW] #2556288
09/29/18 02:58 PM
09/29/18 02:58 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I've been banana grooving them
did you get your belt length yet? I was thinking about that this ,morning.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Rocker shaft orientation [Re: ric3xrt] #2556394
09/29/18 09:01 PM
09/29/18 09:01 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Yes i did.
You have mail
Re: Rocker shaft orientation [Re: MattW] #2590596
12/11/18 10:00 PM
12/11/18 10:00 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Bump
Re: Rocker shaft orientation [Re: MattW] #2814358
08/28/20 01:10 PM
08/28/20 01:10 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So i was assembling a 5.7 today and I came back to this topic.
Easiest solution is this.
Notch up and pointed to your right
Intake rocker arm, NOT pushrod side, pointed to you.
This is for all shafts and rockers.
Matt
Re: Rocker shaft orientation [Re: MattW] #2823919
09/23/20 08:05 AM
09/23/20 08:05 AM
New Jersey
Button Offline
Button  Offline
New Jersey
