msd 8636 crank trigger #2551872
09/19/18 11:31 AM
09/19/18 11:31 AM
illinois
dodgeram1998 Offline OP
illinois
will it be a bolt on with a fluidamper or do i need a flat flat face ati damper or some sort of spacer with a fluidamper
Re: msd 8636 crank trigger [Re: dodgeram1998] #2553854
09/23/18 10:18 PM
09/23/18 10:18 PM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline
JT612GTX  Offline
should just bolt right on, I never had a problem bolting on crank triggers on any other balancers, yours dont have a flat face?
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
Re: msd 8636 crank trigger [Re: dodgeram1998] #2553891
09/23/18 11:36 PM
09/23/18 11:36 PM
illinois
illinois
myfluidamper. does not have a flatsurface across the whole front, the pulley mounting surface is recessed , lesson learned now i have to get a diff flat faced damper
Re: msd 8636 crank trigger [Re: dodgeram1998] #2553927
09/24/18 01:06 AM
09/24/18 01:06 AM
AndyF Offline
AndyF  Offline
Use a spacer
Re: msd 8636 crank trigger [Re: dodgeram1998] #2553967
09/24/18 08:29 AM
09/24/18 08:29 AM
illinois
illinois
whom has spacer ?
Re: msd 8636 crank trigger [Re: dodgeram1998] #2553969
09/24/18 08:43 AM
09/24/18 08:43 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Any sort of spacer or washer will work. They just all need to be real close in matching thickness so that the trigger wheel goes around straight. You can probably find something that will work at Lowes or Home Depot by you.
[image][/image]
Re: msd 8636 crank trigger [Re: sgcuda] #2553985
09/24/18 10:20 AM
09/24/18 10:20 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Mancini
Michael Doty
Personally, I'd email Doty Mfg, and see what the lead time is. If you're desperate, Mancini is your list price winner.
Re: msd 8636 crank trigger [Re: dodgeram1998] #2554057
09/24/18 01:27 PM
09/24/18 01:27 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I agree. I have used the one from Doty. Nice piece. I think Mancini sells them.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: msd 8636 crank trigger [Re: dodgeram1998] #2554058
09/24/18 01:27 PM
09/24/18 01:27 PM
AndyF Offline
AndyF  Offline
Originally Posted By dodgeram1998
whom has spacer ?
It takes a machine shop to build a Mopar.
Re: msd 8636 crank trigger [Re: dodgeram1998] #2554169
09/24/18 06:17 PM
09/24/18 06:17 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
And a lot of patience.
2011 Drag Pak Challenger
Re: msd 8636 crank trigger [Re: dodgeram1998] #2555654
09/27/18 07:23 PM
09/27/18 07:23 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
whom has spacer ?
Doty
https://www.dotymi.com/
Re: msd 8636 crank trigger [Re: dodgeram1998] #2555935
09/28/18 12:19 PM
09/28/18 12:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had to make a lot of the front dress of my engine also for spacers, brackets etc. What I should have done was bought a Big Block Mopar damper with a Big block Chevy bolt pattern & would have been much easier with the selection of parts/mandrels out there for Chevy's.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: msd 8636 crank trigger [Re: dodgeram1998] #2556036
09/28/18 04:46 PM
09/28/18 04:46 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
AEROSPACE components has the measurements for the spacer. i had them make me one last year due to this problem. machinist said he never heard of this being a problem and i told him just wait, you will. i believe they have it programmed to make now.
Re: msd 8636 crank trigger [Re: dodgeram1998] #2556103
09/28/18 09:35 PM
09/28/18 09:35 PM
illinois
illinois
thank you for info
