rear sway bar in Cuda with Dana 60 #2553273
09/22/18 04:11 PM
09/22/18 04:11 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Hi, I've searched the net and was unable to find a concrete answer, so here it goes - could you get a rear sway bar in a 1971 'Cuda that was equipped with a Dana 60 rear? Everything I've found suggests no, but I'd like to know 100% for sure. Thanks, Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: rear sway bar in Cuda with Dana 60 [Re: FJ6AAR] #2553276
09/22/18 04:19 PM
09/22/18 04:19 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
the '72 B-body is the only DANA 60 car that a rear sway bar was available
frog the answer is NO for a 1971 'cuda
Re: rear sway bar in Cuda with Dana 60 [Re: FJ6AAR] #2553314
09/22/18 06:34 PM
09/22/18 06:34 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Thank you Dan, much appreciated. Rob
Re: rear sway bar in Cuda with Dana 60 [Re: FJ6AAR] #2553337
09/22/18 07:31 PM
09/22/18 07:31 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Correct. No sway bar with the Dana. Have had a few Dana cars and evidence of a sway bar on any of them.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: rear sway bar in Cuda with Dana 60 [Re: FJ6AAR] #2553513
09/23/18 08:00 AM
09/23/18 08:00 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
If one wanted to, what is involved with installing a sway bar on a 71 cuda with a Dana 60? Will a factory bar and setup from a 8-3/4 work?
Re: rear sway bar in Cuda with Dana 60 [Re: larry4406] #2553579
09/23/18 12:21 PM
09/23/18 12:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I bolted a Firm Feel rear bar in my '70 , but I'm using a '68 B-Body Dana with Dr Diff's inset hanger kit.
There's no reason you can't bolt one in to your car too. The chassis mount brackets slip over the frame and are screwed on to hold. The bar end mounts simply sandwich above the springs and between the rear end housing.
Call Firm Feel and tell them you need a rear bar & installation kit for your wider rear end. The bar ends need to reach to the middle of the leaf spring.
You can see the end links in this photo.
Re: rear sway bar in Cuda with Dana 60 [Re: jbc426] #2553616
09/23/18 01:49 PM
09/23/18 01:49 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Good to know. I was concerned that the larger "pumpkin" of the Dana 60 compared to the 8-3/4 might mean that a stock sway bar would interfere with the pumpkin.
Re: rear sway bar in Cuda with Dana 60 [Re: FJ6AAR] #2553823
09/23/18 08:50 PM
09/23/18 08:50 PM
BDW Offline
BDW  Offline
My Challenger had the rear sway bar with the 8.75 rear end, changed over to a Dana and it bolted up the same with no issues.
Re: rear sway bar in Cuda with Dana 60 [Re: BDW] #2553963
09/24/18 07:54 AM
09/24/18 07:54 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Good news!
Re: rear sway bar in Cuda with Dana 60 [Re: FJ6AAR] #2553991
09/24/18 10:40 AM
09/24/18 10:40 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
A good question to ask would be why the suspension engineers decided against having one with a Dana on an E-body. Maybe the leaf spring packs were deemed stiff enough on the E-bodies that required Dana's?
Re: rear sway bar in Cuda with Dana 60 [Re: FJ6AAR] #2554004
09/24/18 11:10 AM
09/24/18 11:10 AM
BDW Offline
BDW  Offline
If you bought an engine package that required the Dana, you just wanted to go straight.....
