Need help of moparts #2553668
09/23/18 03:33 PM
09/23/18 03:33 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I am in need of a 360-1 indy cylinder 1.6 rocker for my number 6 exhaust side. I called indy a few weeks ago to order one and they took all my info and credit card info but neglected to tell me they didn't have any in stock and are not making them any more, of course until I called them two weeks later when I got home from out of town. So now I have to spend $1200 on all new over the winter. I sure would appreciate it if I could buy someone's spare if one still exists.
they are blue in color and for the #6 exhaust valve.
thank you Moparts
Thank you
Kiddart
Re: Need help of moparts [Re: Kiddart] #2553677
09/23/18 04:17 PM
09/23/18 04:17 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Check with Dove. They were making them for Indy...
http://www.dovemanufacturing.com/
Re: Need help of moparts [Re: Kiddart] #2553678
09/23/18 04:17 PM
09/23/18 04:17 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Sorry I can’t help you now but I have a set on my Duster I hope to set over during the Winter. I bought a set of T&D rockers off another member that switched to a big block. Did you happen to compare an Indy exhaust rocker with a Craine rocker. Or maybe contact Dove as I’ve heard they made Indy’s rockers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need help of moparts [Re: sixpakdodge] #2553679
09/23/18 04:18 PM
09/23/18 04:18 PM
PA.
"Little"John
"Little"John
PA.
You beat me. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Need help of moparts [Re: Kiddart] #2553706
09/23/18 04:59 PM
09/23/18 04:59 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
PM me. I have a set with a couple missing
"Just a Bracket car dressed up like a streetcar"
Re: Need help of moparts [Re: Kiddart] #2553880
09/23/18 11:06 PM
09/23/18 11:06 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I will check with Dove as well. someone at Indy said if I went with the Jezel set I don't have to change my push rods. is that a true statement? wouldn't a offset 1.6 rocker for a 360-1 set up be the same across manufactures, after all they are adjustable.
I may not understand what would be different.
Thank you
Kiddart
