possible max wedge sport fury
#2553412
09/22/18 11:25 PM
09/22/18 11:25 PM
Posts: 157 wi
Furys
wi
bought a sport fury about 6-7 years ago,no motor tranz,roller,not much interior,been working on it making a street rod type ride,in my checking out the numbers on the car I have found out it may be a max wedge car,the fender tag shows a 9 under the motor number,anyway all the numbers match the fender tag,cowel,speaker tray etc,my question is I don want to retore this car if its a max wedge car,whats something like this worth without motor,rear end tranz?
Re: possible max wedge sport fury
[Re: Furys]
#2553426
09/22/18 11:59 PM
09/22/18 11:59 PM
Posts: 157 wi
Furys
wi
no battery anywhere front or back,car was pretty stripped how ever there are a few holes in the pass side of the trunk,we dodnt know what they were for
[Re: Furys]
#2553718
09/23/18 05:14 PM
09/23/18 05:14 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
also read that the 63 steel front end max wedge cars had the battery in the front,only 63,s that had the batteries in the back were the lightweights Depends on the build date, battery moved to trunk on all MW cars February 1963.
[Re: topside]
#2553994
09/24/18 10:48 AM
09/24/18 10:48 AM
Posts: 4,283 Florida
blewbyu
You really ought to buy the Davis book on Maxies if you even THINK you have one. Documentation is key, and the info in his book is thorough & fascinating in any case. I tried to buy one of his books awhile back and they are not available at this time. I did e mail him about a car and he responded quickly the other day about a car I had found. If you e mail him the vin you can find out very quickly if its a real max wedge car. ddavis8839@aol.com
[Re: cudaman1969]
#2554040
09/24/18 12:32 PM
09/24/18 12:32 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Look at the pass front brake line on the firewall, Max wedge where routed in a different spot than standard engines. Like this,brake line from master cylinder is also unique.
[Re: 62maxwgn]
#2554047
09/24/18 12:42 PM
09/24/18 12:42 PM
John_Kunkel
Rio Linda, CA
MW with A/C? Gotta be a clone.
On the correct MW firewall the most noticeable differences, besides the cross-firewall brake line, are the relocated voltage regulator, engine wiring harness and the rerouted brake line from the MC. All of these are easily replicated. I believe the one thing that is usually ignored when cloning a MW is the extra parking brake cable guides welded to the underside of the floor pan.
[Re: 62maxwgn]
#2554159
09/24/18 05:39 PM
09/24/18 05:39 PM
John_Kunkel
Rio Linda, CA
I once saw a pic of what was reputed to be a MW prototype, instead of the cable guides welded to the floor pan they drilled holes in the floor and installed a couple of seat belt eyebolts and routed the cable through them. I did the same thing when I built my MW clone.
[Re: John_Kunkel]
#2554163
09/24/18 05:58 PM
09/24/18 05:58 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
it is not a mystery there were pics in his other thread post the VIN - someone will let you know if the VIN is in DD's book
[Re: 6bblgt]
#2554335
09/25/18 01:59 AM
09/25/18 01:59 AM
Posts: 3,089 Michigan
A727Tflite
it is not a mystery there were pics in his other thread post the VIN - someone will let you know if the VIN is in DD's book What other thread.
[Re: Furys]
#2559263
10/05/18 06:42 AM
10/05/18 06:42 AM
Posts: 94 Melbourne
ossietim
Melbourne
You can send me the Vin in a pm. The one too keep private is the SO number off the tag & body numbers I have book no.1
