Corner weights, SS springs, street driving, what works well? #2552989
09/21/18 06:36 PM
09/21/18 06:36 PM
gregsdart Offline OP
I put SS springs on my 65 Dart street car, and finally got it scaled. I was surprised to see the hi bias, left front/ right rear.
Lf 911 rf 832
Lr 646 rr 726
The car is level at these weights, no driver.
My question is, how much bias can be in the corner weights and still produce decent street manners?
I can remove most, but the passenger side of the car sits over an inch higher than the drivers side, and that is before i put my 265 in the seat!
Re: Corner weights, SS springs, street driving, what works well? [Re: gregsdart] #2553029
09/21/18 08:25 PM
09/21/18 08:25 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
You should scale it with you in the car unless you are remote driving it. You may be surprised at how much of your weight goes to rear of car depending on seat location (which I suspect is a ways from the steering wheel).
Real Men shift for themselves
Re: Corner weights, SS springs, street driving, what works well? [Re: 1DGEMAN] #2553266
09/22/18 03:47 PM
09/22/18 03:47 PM
IN
ahy Offline
ahy  Offline
IN
Handling guys running SS springs often run two the same (eg two rights). You could do the same... if you like the way it drives with SS springs.
I am running XHD + 1 full leaf on a Challenger. This is a less extreme bias design. Also 1" T bars up front. This works well and no extreme L/R height difference.
Re: Corner weights, SS springs, street driving, what works well? [Re: gregsdart] #2553405
09/22/18 11:08 PM
09/22/18 11:08 PM
I mainly want good weight transfer for traction, and very stable steering when cruising.
Re: Corner weights, SS springs, street driving, what works well? [Re: gregsdart] #2553446
09/23/18 01:07 AM
09/23/18 01:07 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've run a couple of cars with SS springs on the street - an early B-body and an A-body, and both rode & drove like normal Mopars.
As for the R/R being high, cranking up the L/F torsion bar a bit evens that out.
Driver weight should be in the seat, 1/2 tank fuel, as you're looking for as-driven conditions.
Re: Corner weights, SS springs, street driving, what works well? [Re: gregsdart] #2553448
09/23/18 01:08 AM
09/23/18 01:08 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
how is the rf lower than the lf. isn't the engine offset to the passenger side.
Re: Corner weights, SS springs, street driving, what works well? [Re: gregsdart] #2553455
09/23/18 01:32 AM
09/23/18 01:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Greg.. take the car to a good spring shop and
have them lower the rear and keep it level..
you want to be there because you will be getting
in and out of the seat.. how far does it need
to be lowered to be just lower than the front..
take measurement so you get it right.. I did
this on my 69 Valiant.. I ended up lowering the
front end by 1/2" to get what I wanted
wave
Re: Corner weights, SS springs, street driving, what works well? [Re: gregsdart] #2553495
09/23/18 03:49 AM
09/23/18 03:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the 3400 lb SS springs on my 63. I had to do the same thing Topside did as on most cars I put SS springs on they usually sit a bit un-level and I have to either raise or lower the torsion bars to even the car out. I had to do it on my 63. I have never scaled the car but it goes nice and straight at the track and drives just fine on the street. The only thing I notice is the car lifts the left front more then the right front on launch but it goes nice and straight. Ron
Re: Corner weights, SS springs, street driving, what works well? [Re: MR_P_BODY] #2553518
09/23/18 09:00 AM
09/23/18 09:00 AM
wave
Mike, ride height in back is pretty much where it has to be for tire clearance at this point. If I do anything with the back, it may need one step down in SS spring weight. Then I can see if I want to mess with the back more.
Re: Corner weights, SS springs, street driving, what works well? [Re: gregsdart] #2553519
09/23/18 09:02 AM
09/23/18 09:02 AM
Thanks everybody for your input!
