318 Block stampings
#2553315
09/22/18 06:37 PM
09/22/18 06:37 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Hey all,
I know I havent been on for awhile, life and stuff, but I am here to ask a question or two.
Anyway, I am re-sealing an 89 318 for my 72 Fury driver. The motor is out of an 89 Diplomat AHB. I got the pan off and on the rail near each cylinder are markings. Most of them on the drivers side are a "B" with an "X" in a circle, but one is a "C". Same on the other side except on one there is a "C" instead of the "B".
Anyone know what they mean? This motor is already an anomoly, it has a 9/87 casting date but the front is stamped 9M318 which is an 89 motor. Everything else is stamped mid 88.
- Jamie
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
Re: 318 Block stampings
[Re: MoPar Jamie]
#2553319
09/22/18 06:51 PM
09/22/18 06:51 PM
Posts: 3,504 DFW
mr_340
DFW
Piston sizes. Chrysler had select fit pistons in .00025" increments. Look in the service manual for the piston sizes.
Floyd Lippencott IV
[Re: MoPar Jamie]
#2553322
09/22/18 06:56 PM
09/22/18 06:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My 87 Diplomat's 318 has the same kind of markings. As I understand it, there are indications of bore sizing as related to piston fitment during factory assembly. Apparently, there is more to it than just hitting 3.91", A is tightest, B next tightest, C least tight. Not sure what the exact specs that correspond to the A, B, C markings other than they all are still considered standard bore. Mine had a lot of A's.
