rear sway bar in Cuda with Dana 60
#2553273
09/22/18 04:11 PM
09/22/18 04:11 PM
Posts: 1,549 Mattituck NY.
FJ6AAR
Mattituck NY.
Hi, I've searched the net and was unable to find a concrete answer, so here it goes - could you get a rear sway bar in a 1971 'Cuda that was equipped with a Dana 60 rear? Everything I've found suggests no, but I'd like to know 100% for sure. Thanks, Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: rear sway bar in Cuda with Dana 60
[Re: FJ6AAR]
#2553314
09/22/18 06:34 PM
09/22/18 06:34 PM
FJ6AAR
Mattituck NY.
Thank you Dan, much appreciated. Rob
[Re: larry4406]
#2553579
09/23/18 12:21 PM
09/23/18 12:21 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I bolted a Firm Feel rear bar in my '70 , but I'm using a '68 B-Body Dana with Dr Diff's inset hanger kit.
There's no reason you can't bolt one in to your car too. The chassis mount brackets slip over the frame and are screwed on to hold. The bar end mounts simply sandwich above the springs and between the rear end housing.
Call Firm Feel and tell them you need a rear bar & installation kit for your wider rear end. The bar ends need to reach to the middle of the leaf spring.
You can see the end links in this photo.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2553616
09/23/18 01:49 PM
09/23/18 01:49 PM
Posts: 521 Virginia
larry4406
Virginia
Good to know. I was concerned that the larger "pumpkin" of the Dana 60 compared to the 8-3/4 might mean that a stock sway bar would interfere with the pumpkin.
[Re: BDW]
#2553963
09/24/18 07:54 AM
09/24/18 07:54 AM
Posts: 521 Virginia
larry4406
Virginia
My Challenger had the rear sway bar with the 8.75 rear end, changed over to a Dana and it bolted up the same with no issues. Good news!
