torqueflite dip stick seal #2549088
09/12/18 01:24 AM
09/12/18 01:24 AM
Jefferson State
srt Online content OP
ESYC
srt  Online Content OP
ESYC
Jefferson State
Anyone know if there's a source for a replacement dip stick seal. This is for the one fitted into the umbrella cap of the dipstick to seal off the top of the tube. My searches yield seals for the bottom of the tube only.
Re: torqueflite dip stick seal [Re: srt] #2549090
09/12/18 01:50 AM
09/12/18 01:50 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't remember there being a seal at the top of the tube but I really never looked.
Re: torqueflite dip stick seal [Re: srt] #2549105
09/12/18 02:58 AM
09/12/18 02:58 AM
Jefferson State
ESYC
ESYC
Jefferson State
Mine (68 727) has a black rubber plug about 1/2" tall molded with a slot for the dipstick and appears to have been cut vertically on one "edge" of the stick to open up and close back around the stick, sort of "c" shaped piece that closes shut when pushed up into the cap.
Re: torqueflite dip stick seal [Re: srt] #2549302
09/12/18 05:55 PM
09/12/18 05:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
To my knowledge, that seal was never offered separately, it's considered to be part of the dipstick assembly.
Re: torqueflite dip stick seal [Re: srt] #2549454
09/13/18 12:22 AM
09/13/18 12:22 AM
Jefferson State
ESYC
ESYC
Jefferson State
I may have to spring for the smallest most expensive seal (buy an assembly for the thing)!
Re: torqueflite dip stick seal [Re: srt] #2550729
09/16/18 07:44 PM
09/16/18 07:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a NOS trans dipstick for a dodge van. You could take the seal off of that to use on your stick.
Re: torqueflite dip stick seal [Re: mopars4ever] #2550751
09/16/18 08:33 PM
09/16/18 08:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Problem is, it's not as easy as just slipping on a new seal; the rubber seal at the top of the dipstick is retained by a steel washer that's held in place by staking the dipstick. Not saying it can't be done but it's not a simple slip-on.
Re: torqueflite dip stick seal [Re: srt] #2551013
09/17/18 12:36 PM
09/17/18 12:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
nos stick
Re: torqueflite dip stick seal [Re: srt] #2551329
09/18/18 12:08 AM
09/18/18 12:08 AM
Jefferson State
ESYC
ESYC
Jefferson State
I took a good look at mine. The raised collar is there only as a short remnant, appears the tube riding close to an after market header ran it hot enough to shrink it, and likely harden the rubber causing it to shrink and fail.
The metal "cap" of the dip stick is loose enough to slide up and around the handle (round finger hole) of the stick allowing the plug to be slid onto the stick above the washer and the cap returned, and the shape of the handle restored.
This can be accomplished IF a new rubber plug is flexible enough to slide around the handle and over the swedge that retains the cap in place without damage.
Re: torqueflite dip stick seal [Re: srt] #2551497
09/18/18 01:54 PM
09/18/18 01:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the swedge that retains the cap isn't intact, the cap can slide up and your level readings will be off.
Re: torqueflite dip stick seal [Re: John_Kunkel] #2551925
09/19/18 01:49 PM
09/19/18 01:49 PM
Jefferson State
ESYC
ESYC
Jefferson State
I got it.
The original cap has just enough wear it can be tilted and worked around the swedge. After reinstalling a slight additional swedge, or squeeze with clamp or cushioned plier will keep it retained.
Another of the little problems these old cars present.
I'm more curious as how to get more clearance so the melt does not re-occur.
Re: torqueflite dip stick seal [Re: srt] #2551992
09/19/18 05:03 PM
09/19/18 05:03 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
May not be the route you want to go but I put these in everything now...Not a drop of transmission fluid on the floor ever... up
https://www.summitracing.com/parts/lok-td-3727fm/overview/
...FAFO...
Re: torqueflite dip stick seal [Re: skicker] #2552314
09/20/18 01:58 PM
09/20/18 01:58 PM
moparx Offline
moparx  Offline
while i like the idea of a flexible tube, those lokar deals upset me because of the small internal diameter of the tube, and the length of time it tales ME to fill the transmission ! your mileage may vary.
beer
Re: torqueflite dip stick seal [Re: moparx] #2552469
09/20/18 07:42 PM
09/20/18 07:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree And the fluid level is hard to see on the stick.
Re: torqueflite dip stick seal [Re: srt] #2552522
09/20/18 09:25 PM
09/20/18 09:25 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I bought one of these: http://www.manciniracing.com/man727diptub.html. My local track (Tulsa) likes to see the locking type even on the slower cars.
Re: torqueflite dip stick seal [Re: srt] #2552673
09/21/18 01:23 AM
09/21/18 01:23 AM
Jefferson State
ESYC
ESYC
Jefferson State
With great help from mopars4ever I now have what appears to be the correct seal for my original. I'll be massaging it together in the near future.
Thank everyone for suggestions and help!
