440 EDM Lifters
#2552385
09/20/18 04:29 PM
09/20/18 04:29 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
Getting ready to build a 440. Will be using TrickFlow 240 heads and a Comp flat tappet 23-631-5 which I planned on getting the nitride treatment. I saw AndyF's article about also using the 2901-16 EDM lifters for extra safety. When I looked up those lifters it said they used pushrod oiling? I've assumed the HS rockers for the trickflow head were still oiled via the shaft? Is there something i'm missing if I do wish to run these EDM lifters? Thanks!
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
Re: 440 EDM Lifters
[Re: W5Duster436]
#2552388
09/20/18 04:35 PM
09/20/18 04:35 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The edm lifters are based on the AMC lifter, so they have pushrod oiling...... cuz AMC’s use it.
You don’t want pushrod oiling? No biggie...... just get pushrods with no holes.
Re: 440 EDM Lifters
[Re: fast68plymouth]
#2552393
09/20/18 04:48 PM
09/20/18 04:48 PM
W5Duster436
Indiana
I'm for whatever works. Thanks Dwayne. Didn't want to keep bothering you via email. So the rockers will still get oiling via shaft and all I need to do is buy 3/8 pushrods etc. with holes and it will run oil up to the rocker tip as well as oil the lobe? I assumed since lifters already were fed via the gallery that they'd pressurize that small hole anyway. I've been out of the engine game for way too long to remember half this stuff. :-)
Re: 440 EDM Lifters
[Re: W5Duster436]
#2552397
09/20/18 05:00 PM
09/20/18 05:00 PM
fast68plymouth
So. Burlington, Vt.
You can oil both through the head and up the pushrods if you want, but unless the cam is pretty aggressive and the spring pressures quite high, I’d do one or the other.
With HS rockers and a flat tappet cam, I’d just use the oe style oiling.
Re: 440 EDM Lifters
#2552402
09/20/18 05:13 PM
09/20/18 05:13 PM
W5Duster436
Indiana
I guess my main question was how did the tip of the HS roller rocker and cup of the pushrod get oiled using the stock setup?
Re: 440 EDM Lifters
[Re: W5Duster436]
#2552418
09/20/18 05:55 PM
09/20/18 05:55 PM
fast68plymouth
So. Burlington, Vt.
HS rockers don’t have any provision to oil the tip, whether you pushrod oil or not. Valves and springs are oiled by the “oil mist” inside the valve cover when using those rockers.
There is a splash hole in the rocker body that directs oil into the pushrod cup that’s fed by the oil in the shafts.
That is the “normal” oiling set up.
Re: 440 EDM Lifters
[Re: W5Duster436]
#2552691
09/21/18 03:08 AM
09/21/18 03:08 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
It's not a bad idea to restrict and send a little oil up the PRs to eliminate the possibility of burnt cups.
Re: 440 EDM Lifters
[Re: W5Duster436]
#2553451
09/23/18 01:18 AM
09/23/18 01:18 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I get my lifters from Comp Cams. I order them without pushrods oiling. My thought is why do I want 16 little oil leaks when I don't need it? I too order them with the EDM oil hole on the face. I've never had a oiling problem with this combo.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 440 EDM Lifters
[Re: W5Duster436]
#2553469
09/23/18 02:14 AM
09/23/18 02:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have W-2 and W-5 heads..both oil via the PRs.. and the W-2s have EDM holes.. all I do is put a 1/16" NPT plug in the port in the block before I put the heads on.. been working fine for a few years now.. I do have restricted PRs.. I just set up the W-5s and checked the oil flow yesterday and it looked great.. both sets use the TD multi shaft rockers
