904/A500 aftermarket lockup converter front cover? #2552302
09/20/18 01:42 PM
09/20/18 01:42 PM
Colorado front range
BcudaChris Offline OP
Does anyone know of an aftermarket 904/A500 converter cover that will take a lockup clutch? I'm currently running a re-worked stocker, but would like another 300 RPM stall.
Re: 904/A500 aftermarket lockup converter front cover? [Re: BcudaChris] #2552380
09/20/18 04:17 PM
09/20/18 04:17 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I had a TCI Hole Shot converter years ago when I was still running a 360/500. It was rated at 2400 and had lock-up.
Re: 904/A500 aftermarket lockup converter front cover? [Re: BcudaChris] #2552395
09/20/18 04:51 PM
09/20/18 04:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The issue with high stall and lock up is that
the area in the bell housing isnt thick enough
for them.. I was going to have one built for a
518 but it was crazy pricey.. I'm running a
4800 stall 8" in my Rampage behind a 416ci.. it has
OD but no lock up.. it has a switch for OD or I
can leave it on and it will shift into OD as
soon as it hits high gear.. I mainly leave it on
for the OD most of the time.. I only turn it off
if I am racing it
wave
Re: 904/A500 aftermarket lockup converter front cover? [Re: BcudaChris] #2552436
09/20/18 06:38 PM
09/20/18 06:38 PM
A727Tflite Offline
A727Tflite  Offline
Lockup converters are no different externally from non-lockup.
Unless you plan on using lockup while wide open throttle - any good converter shop can build you one using the correct core.
Re: 904/A500 aftermarket lockup converter front cover? [Re: BcudaChris] #2552439
09/20/18 06:51 PM
09/20/18 06:51 PM
Yeah, my current converter is a PTC unit comparable to the Holeshot/MP166K 904 lockup converters. The core they built it from was from a Dakota R/T.
I've got less than 500 mi on the setup, so I'm thinking it might loosen up a bit given more miles.
I did not know that about the bell housing, I thought I smelled a hole in the market but now I see why. The only answer I got as to why was "no one makes a billet front cover for a lockup 904."
The guy who did my trans for me did say there were lockup covers available for LU 727/518s. I was already committed to the 999 though.
I really only use the LU for cruising. It has a noticeable impact on fuel economy in the 40-60 range.
Re: 904/A500 aftermarket lockup converter front cover? [Re: A727Tflite] #2552442
09/20/18 06:57 PM
09/20/18 06:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its sounds like he wants to run it hard in lock up and
any OD trans that I run wont take that.. it fries the OD
clutch.. the 3 places that I went to said they needed
more room in the bell for more clutch.. I could add
a spacer to the trans to move it back for room but all
that just cost more
wave
Re: 904/A500 aftermarket lockup converter front cover? [Re: BcudaChris] #2552657
09/21/18 12:54 AM
09/21/18 12:54 AM
A727Tflite Offline
A727Tflite  Offline
