well, ive given it thought, and mainly, safety is what won. i can find the pads for the calipers i have, all i need is pistons, but theres like 3 different widths for the 1.75 pistons.
so now, im looking for a set of calipers with 5.25 bolt spacing.
also, i know that rotor thickness is an option with the calipers, i cleaned my rotors up on a brake lathe, and took a couple thou's off.
with a tape measure i can tell they are around 5/16's which is like .3125 thick so mine are that give or take a few thousands... would they be okay with a caliper made for .32? i dont see why not, but just clearing it up
so i need a caliper with 5.25 bolt spacing, and made for a .32 rotor.
whats out there to check out?
