Re: big block ultrabell to A518 part # ?
[Re: JAMESDART]
#2553207
09/22/18 12:33 PM
09/22/18 12:33 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
I always wondered, if you have to use an ultrabell anyway is it worth using the 518, or just go with a 4l60 or something else? I am putting a 48re behind one....
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: moparx]
#2553736
09/23/18 05:42 PM
09/23/18 05:42 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think '97...in '98 the speedo sensor moved to the rear end.
[Re: Jambbii]
#2558818
10/04/18 11:20 AM
10/04/18 11:20 AM
Posts: 516 Hanover, Ontario, Canada
Moparmatty
I always wondered, if you have to use an ultrabell anyway is it worth using the 518, or just go with a 4l60 or something else? I am putting a 48re behind one.... Are you installing an Ultrabell onto the 48RE?
Matt Tebbutt Ontario, Canada
[Re: JAMESDART]
#2558880
10/04/18 01:34 PM
10/04/18 01:34 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I always wondered, if you have to use an ultrabell anyway is it worth using the 518, or just go with a 4l60 or something else? The best transmission I have ever owned and driven is an Extreme Automatics built 200R4 with a Precision of New Hampton 3800 stall, lock-up, billet converter bolted to my 408 Magnum with a Reid bell housing. They can be built to handle up to 1000 hp & 800ft lbs of torque, are more efficient and are compact. I didn't have to cut my floor either.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
