Re: Burnt fusible link - help
[Re: MoparABE]
#2551770
09/19/18 01:05 AM
09/19/18 01:05 AM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
I agree. Check the positive stud on the back of the alternator as I've had them loosen up on my car over the years. Also, the ammeter could be a potential problem too if the thing grounded out.
inherited a 69 roadrunner from my grand pop.
[Re: MoparABE]
#2551883
09/19/18 11:51 AM
09/19/18 11:51 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
I had experienced in the past the fields in the alternator reverse polarity. When that happened it did snap the fusible link.
Run some wire from the battery stud back of the alternator to the battery stud at starter relay WITH A FUSIBLE LINK! If the link snaps right away,the alternator is no good. If everything lights up and runs fine,the ammeter gauge is no good. You can leave this jumper wire in permanently since it takes a load off the ammeter gauge and completes the curcuit between the + and - side of the charging system. Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: MoparABE]
#2551936
09/19/18 02:14 PM
09/19/18 02:14 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
69Cbrge has some good advice. You have a dead-short somewhere. You could temporarily install an inline fuse in that circuit & carry a stack of fuses until you figure it out.
Anyway, check the charging system first as noted above + bulkhead disconnect. If those check out, start going circuit by circuit & disconnect them.....when your "fusible link fuses" stop blowing, then you know what circuit you have a short. Check your wiring diagram & see what's on that circuit. PIA, but basically just tracking down a short
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2551954
09/19/18 03:03 PM
09/19/18 03:03 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You have a dead-short somewhere. You could temporarily install an inline fuse in that circuit & carry a stack of fuses until you figure it out. A breaker would be better.
[Re: MoparABE]
#2552915
09/21/18 04:21 PM
09/21/18 04:21 PM
68Cbarge
Canuckville
Thanks for the help, I traced it to a bad alternator, it was shorted internally causing a direct short to ground. I knew I was on the right track! Glad you found it! As mentioned before,leave the jumper wire in. Also for added insurance, bypass the bulkhead connector for the MAIN red wire.
