Carburetor - what to use for lubrication?
#2551333
09/18/18 12:16 AM
09/18/18 12:16 AM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Is there a good product to lubricate a carburetor's butterfly shaft?
Online there is mention of CRC Spray, lubes that leave behind dry graphite or teflon, also white lithium which I have on my shelf.. ..anyone have experience or recommendations?
The main throttle shaft on my Plymouth's Carter is sticking a little and won't always return the last fraction of an inch to bring the engine down to a nice low idle..
I have to blip the gas pedal to coax it down.. or else the engine pushes against the brakes, etc, etc. .. sometimes it just refuses to cooperate at all, and I hate fighting the engine with the brakes..
I've added a return spring, that helped a little, but it needs that little extra...
Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Carburetor - what to use for lubrication?
[Re: calrobb2000]
#2551361
09/18/18 01:54 AM
09/18/18 01:54 AM
RapidRobert
As said, first find out if it is dirt/varnish or a mech binding. Soak it or spray clean it for starters
[Re: 67SATisfaction]
#2551414
09/18/18 10:42 AM
09/18/18 10:42 AM
67SATisfaction
Albany, NY
Thanks guys.
Glad I asked, I'll follow your advice and re-check the carb shaft and throttle cable separately.
The carb was rebuilt this spring including all parts submerged in a bucket of NAPA carb cleaner. It seemed to me the butterfly shaft is now so dry, it's binding, that's why dry lube like graphite or teflon made sense. I will get some and apply a little to see if that does the trick.
The throttle cable I checked this spring. I disconnected both the carb end and pedal end to ensure I had easy action through the sleeve, and lubed with light weight sewing machine oil.... I'll check it again.
I checked the pedal lever and pivot for binding or interference from the interior carpet. It's not perfect, so I'll check there again..
I can also see what a stronger spring does..
Thanks, - Art
#2551465
09/18/18 12:27 PM
09/18/18 12:27 PM
RapidRobert
Art save yourself a trip & forget about the lube. Keep after it & find out if it is varnish/debris OR throttle plates (something metal on metal) that is binding.
