Milodon feed hits the steering bracket #2551249
09/17/18 08:50 PM
09/17/18 08:50 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
My steering is in contact with the feed line. I'm going to take the engine back out again. Do you guys have a nice way to accomplish this.
Thanks.......Ted
Re: Milodon feed hits the steering bracket [Re: DusTed74] #2551269
09/17/18 09:30 PM
09/17/18 09:30 PM
Thanks.......Ted
Which Milidon pump top cover are you trying to use, top feed or rear feed?
EDITED, what year and body style are you working on also?
Re: Milodon feed hits the steering bracket [Re: DusTed74] #2551274
09/17/18 09:39 PM
09/17/18 09:39 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
If you can't tuck it between the box and the panrail, I've seen them wrapped under the K frame without issue.
What is your setup that you need external lines? I sent my kit back after fighting fitment for a week.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Milodon feed hits the steering bracket [Re: DusTed74] #2551275
09/17/18 09:46 PM
09/17/18 09:46 PM
AndyF Offline
AndyF  Offline
That has been an issue for at least the last 30 years. Some guys use a motor plate and cut away the factory motor mounts to free up some space. I've seen various modifications to the K frame in the area of the steering box to provide room for the external oiling systems. A body cars require more work in that area than B or E body cars.
Re: Milodon feed hits the steering bracket [Re: DusTed74] #2551332
09/18/18 12:16 AM
09/18/18 12:16 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
This is in an E Body and I'm using the sandwich plate. I found that a bulkhead 90 degree fitting into the pump cover was the shortest way out. And then both lines go up and then loop down between the damper and the oil filter. I had the engine in and out several times before I had removed just enough from the steering box support plate. The sandwich plate is a poor solution. At least the pump cover is one piece (no green gasket). I've been running this for ~5 years no with no oiling issues. I did train the curve on that top SS hose when I bent it into that tight radius. I had it squished between two parallel steel plates with c-clamps as I bent it to make sure it didn't collapse. I left it in the squish jig for a couple of days before I released it and made the final connection. I suppose that I should mount a GoPro in there to see if it collapses at high RPM but the hose is really stiff at the bend so I feel comfortable with the solution.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Milodon feed hits the steering bracket [Re: DusTed74] #2551494
09/18/18 01:52 PM
09/18/18 01:52 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
I should have told you this. I have a 72 Demon and I'm running the cover from Milodon with oil supply in the rear.
I have ground on the steering box to clear but it exposed the where two pieces meet.
I'm going to pull the motor then its much easier to get at.
Ted
