Page 3 of 3 1 2 3
Re: What cam would I have used in the 70's [Re: lostdog] #2551159
09/17/18 05:41 PM
09/17/18 05:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In 1981 when I was building my first 440, I bought a Crower Monarch 280H for $66.
280/280 advertised, 224/224@.050, 110lsa, 460/460 lift.
That was a decent little cam.
Re: What cam would I have used in the 70's [Re: fast68plymouth] #2551182
09/17/18 06:12 PM
09/17/18 06:12 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
my first performance cam was a crower 201hj; 284/.480. best running little street cam I put in my 383 road chicken.
Re: What cam would I have used in the 70's [Re: lewtot184] #2551192
09/17/18 06:36 PM
09/17/18 06:36 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
In 1987 I switched from the purple shaft hydralic .455 RV cam with a Holley 650 vac. sec. to that .509/292 purple cam in my 1969 300 440 big block, with factory oem compression(10 to 1) and stock 906 heads (except for a fresh valve job with stock valves). And the Holley 750 #3310 carb. It made a HUGE NIGHT AND DAY DIFFERENCE in performance! I had power brakes, which worked fine with that .509 and it idled around 800 RPM or so in gear. That big car could do tremendous burnouts, AND keep up with new Buick Grand Nationals on the street ! drive
Plymouth Makes It!
Re: What cam would I have used in the 70's [Re: lewtot184] #2551268
09/17/18 09:30 PM
09/17/18 09:30 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Originally Posted By lewtot184
the isky 1012b was the '64 s/s wedge race cam; 320 degrees duration, .520 lift, 108lsa, a lot of cam. the 1012b was superseded by the racer brown stx series; stx21, 22, & 23. the ssh25 and 284-.484 are identical for all practical purposes. the real issue may be how much head modifications your willing to do to run a high lift cam. there are 114lsa versions of the 284-.484 and 292-.509. in my opinion, none of the above.
The "hemi grind" was available through all of the 70s. It had 284°/284°, 0.465" lift and 60° OL. I don't know when the rest of the "purple shaft" DC cams came out, but in 1976 Ma Mopar was still recommending the Racer Brown SSH25 and SSH44 hydraulic cams. I tried one of each before I went to a Crower solid. My buddy was running the mini-express with mushroom tappets. That thing was Bad Azzzz.
Re: What cam would I have used in the 70's [Re: lostdog] #2551280
09/17/18 09:59 PM
09/17/18 09:59 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Yes the MP Mushroom cam and Lifter .690 lift up
With Speed Pro 11.5 (Boat Anchor - Heavy) pistons
on Sunoco 97 or Shell 95.5 gas
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: What cam would I have used in the 70's [Re: BSB67] #2551301
09/17/18 10:54 PM
09/17/18 10:54 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I think when racer brown died and the business changed mopar changed.
Re: What cam would I have used in the 70's [Re: moparts] #2551311
09/17/18 11:14 PM
09/17/18 11:14 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
There are actually two Mini-Express mushroom cams, the 316 duration (278 @ .050) with .654 gross lift, and the bigger one 328 adv. (don't know the .050) with .690 lift. My '82 D.C. book says the .690 "loses some low speed torque"... whistling
I built my 451 around the smaller one. Reground to restore lobe taper and now .652 and 272 @ .050. Has a really nasty idle, 6-7" Hg at 1000-1100 rpm. Should be fun once I get the A-body reassembled this fall
drive
Re: What cam would I have used in the 70's [Re: lostdog] #2551470
09/18/18 12:36 PM
09/18/18 12:36 PM
So. Burlington, Vt.
So. Burlington, Vt.
On my list of “1000 things I’d like to test on the dyno(that will likely never happen)” would be a cam shootout between the old racer brown/DC grinds(ssh-25 and ssh-44)including the hemi grind, vs the updated MP 280, 284, 292 cams, vs the old school Comp 280, 286, 296 Magnum cams, vs the newer Comp Purple Plus 280, 284, 292 cams.
Then toss in some “fast rate stuff”... the Comp XE/HL 275, 285, 295 to see how it all compares.
Re: What cam would I have used in the 70's [Re: lostdog] #2551513
09/18/18 02:25 PM
09/18/18 02:25 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
3/4 race or full race cam
Re: What cam would I have used in the 70's [Re: fast68plymouth] #2551566
09/18/18 04:32 PM
09/18/18 04:32 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Wow, 15 cam changes! Don't forget to degree them all. runaway
Re: What cam would I have used in the 70's [Re: lostdog] #2551602
09/18/18 05:56 PM
09/18/18 05:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
back in the day a friend had a '70 cuda with a 440 6-pak in it. he used a racer brown st21 and swore by it.
Re: What cam would I have used in the 70's [Re: fast68plymouth] #2551677
09/18/18 09:45 PM
09/18/18 09:45 PM
Prospect, PA
Prospect, PA
If you were to guess, what do you think you'd discover?
Re: What cam would I have used in the 70's [Re: lostdog] #2552044
09/19/18 07:38 PM
09/19/18 07:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
Tested on a motor combo good enough to exploit the faster rate cams, and all cams tested using lifters with similar bleed rates, I would expect the faster rate cams to make more power than their slower counterparts........ up to the limiting rpm of the lifters.
Aside from the peak power numbers, I’d be interested in seeing how much higher(if any) the older profiles would rev before the valvetrain got unhappy.
Another test along those lines I think might be revealing would be to try and find some lifters with a nice slow bleed rate, then sort through a tray or so of new stock replacement lifters, find the 32 with the highest bleed rate......... then test the slowest bleed rate vs the fastest bleed rate on the cam that ran into stability problems at the lowest rpm...... and the one that revved the highest before getting unhappy.
The 440 I bought for a core in 1981 had a pretty new DC 292/510 cam in it..... the ssh-44.
I put it in a box, but installed it years later..... actually a couple different times.
The last time was when I was selling my old 448.
I seem to recall it not having any problems turning 6500rpm on the dyno with springs set up at 125/325 and stamped rockers.
That was probably close to 20 years ago now.......... and I’m pretty sure it’s the last time I had a hyd cammed BB Mopar rev that high.
Re: What cam would I have used in the 70's [Re: lostdog] #2552071
09/19/18 09:08 PM
09/19/18 09:08 PM
P
Porter67 Offline
Porter67  Offline
P
My head hurts now.
How do the older oem rate? Ive some sets from the 70-s long before they started putting the nice machine marks on them to get the crown.
Re: What cam would I have used in the 70's [Re: fast68plymouth] #2552132
09/19/18 11:25 PM
09/19/18 11:25 PM
Prospect, PA
Prospect, PA
Thanks Dwayne.
My thoughts are similar. It's as much about the lifter as the lobe profile.
My guess is that the fast rate would probably make more peak if the lifter stays compliant. But if it starts to give it up after peak, the old school still might have greater average hp/area under the curve, ie making the car faster.
My 383 with the new hemi grind and 30 year old lifter will pull decent to 7000 rpm, despite peak power probably at 6000-6200.
Re: What cam would I have used in the 70's [Re: lostdog] #2552247
09/20/18 11:07 AM
09/20/18 11:07 AM
So. Burlington, Vt.
So. Burlington, Vt.
Russ, by the “new” hemi grind...... you mean the 280/.474-110?
I never tried one of those.
Seems like there was some deal where it came without lifters, and by the time you bought the lifters the cost ended up being quite a bit more than a 484 or 509 cam & lifter kit.
If I stumbled across a NIB one now I might pick it up if the price was right.
Fundamentally I like solids so much better it’s unlikely I’d ever use it in one of my own motors though.
Re: What cam would I have used in the 70's [Re: lostdog] #2552256
09/20/18 11:41 AM
09/20/18 11:41 AM
central il.
second 70 Offline
second 70  Offline
central il.
In 1975 I used a crane solid 590 cam in my V code Cuda but it was 13.1 and .030 over. Car had insane torque and power. And 2 miles per gallon. lol
Mike
Re: What cam would I have used in the 70's [Re: second 70] #2552305
09/20/18 01:49 PM
09/20/18 01:49 PM
Iowa
coronetville Offline
Iowa
back in the day all aftermarket except mopar cams and hemi cams had the same chevy grinds on there cams do yourself a favor and let someone with the understanding pick out a real mopar cam for you later is far far better
Re: What cam would I have used in the 70's [Re: coronetville] #2552320
09/20/18 02:09 PM
09/20/18 02:09 PM
moparx Offline
moparx  Offline
racer brown ssh 25/44 with a ch4b or dp4b intake and hooker super comp headers. carb of your choice, starting with at LEAST a 650dp, all the way up to one of those holley "3bbls". 3.91-4.56 gear and b&m holeshot/super holeshot converter.
beer
Re: What cam would I have used in the 70's [Re: fast68plymouth] #2552354
09/20/18 03:26 PM
09/20/18 03:26 PM
Prospect, PA
Prospect, PA
Yes, that's the one. I actually like it. But when I put that one in long ago, I changed a few other things so I cannot really say what improvement were cam related.
Page 3 of 3 1 2 3
