Big block exhaust valves #2550876
09/17/18 01:16 AM
09/17/18 01:16 AM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
What size exhaust valves are being used in most high horsepower big blocks (non-Hemi) nowadays?
Re: Big block exhaust valves [Re: RoadRunnerJD] #2550906
09/17/18 03:53 AM
09/17/18 03:53 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Depends on the heads? 1.81" is pretty common size for larger than stock exhaust in most heads.
The Trick Flow 240s and 270s are using a 1.76" exhaust valve.
Re: Big block exhaust valves [Re: RoadRunnerJD] #2550909
09/17/18 04:05 AM
09/17/18 04:05 AM
It depends on which heads your going to use, stock 1967 and later Hi Po iron heads had 1.74, Eddy RPM and other after market Hi Po aluminum heads have 1.81 and some of the B1 heads have 1.76 work
Indy SR and 440-1 have 1.81 exhaust size also shruggy
Re: Big block exhaust valves [Re: RoadRunnerJD] #2550940
09/17/18 09:59 AM
09/17/18 09:59 AM
Warrenton, VA
Warrenton, VA
The old 426 Stage III had 1.88’s. How come those are not being used in the race heads today?
Re: Big block exhaust valves [Re: RoadRunnerJD] #2550989
09/17/18 11:59 AM
09/17/18 11:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As mentioned, depends on the heads. A smaller exhaust valve leaves room for a larger intake valve.
Re: Big block exhaust valves [Re: RoadRunnerJD] #2551096
09/17/18 03:27 PM
09/17/18 03:27 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Correct me if I'm wrong didn't the 426 notch the top of the cylinders a little on those because the 1.88's got too close? I know we had to on my 383 with 1.88s (Same basic 4.25" bore) This is one of the reasons I wont consider 1.88s, not worth the aggravation plus not much benefit.
Re: Big block exhaust valves [Re: Jwilli500] #2551265
09/17/18 09:23 PM
09/17/18 09:23 PM
[quote=Jwilli500]Correct me if I'm wrong didn't the 426 notch the top of the cylinders a little on those because the 1.88's got too close? I know we had to on my 383 with 1.88s (Same basic 4.25" bore) This is one of the reasons I wont consider 1.88s, not worth the aggravation plus not much benefit.]
You are correct on the larger 1.88 exhaust valves in the 4.250 or smaller bores up
Re: Big block exhaust valves [Re: RoadRunnerJD] #2551784
09/19/18 01:57 AM
09/19/18 01:57 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Put your heads on a non chamfered .030 over bare 440 block, turn it over and tell me what you see. Even some 1.74 heads could benefit from a small notch. When machine shops put 2.14-1.81 valves in they usually unshroud the head making it worse. Put heads on block, turn over, scratch bore circle on head, mark heads left and right, tell shop do not go past this line, if they do you need a notch, unless a ledge in the flow path helps, it may I do not know but doubt it.
Re: Big block exhaust valves [Re: RoadRunnerJD] #2551792
09/19/18 02:19 AM
09/19/18 02:19 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I might add, a felpro 1009 headgasket used as a template to scratch the head before a valve job will need a small notch if they unshroud the head out to the gasket line, an 8519 pt will need a little more, it is just what I have seen looking up thru the bores. Some 400 blocks with the hugh chamfer are good to go. The 1009 is a good template gasket in my opinion, simple notch job.
