My Dyno fetish #2550217
09/15/18 09:52 AM
09/15/18 09:52 AM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
I'm a sick man. I lay awake at night thinking of off the wall kinky things to do on my Dyno. I've tortured stroker Hemis, big blocks and small blocks. My depravity has reached new heights, I bought a set of Chrysler short rams. The test mule will be my unmolested, original, 74 440 Ramcharger motor. 79,000 original miles, I can't wait for the screaming and moaning to begin.
Re: My Dyno fetish [Re: quickd100] #2550236
09/15/18 10:56 AM
09/15/18 10:56 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Well, since you obviously can't control your carnal desires, may I suggest you at least wear protection? I don't want to hear you catching tetanus from rusty header pipes or something. And why must you torture a virgin 440? You're a dirty old man.
Gotta tell you I miss our weekly "Hi Rich, how are you doing? Where the heck is my block?" discussions
blah laugh2
Now that you got your block and your "Pleasure Room", you never call, you never write. What the hell, man.
Rich H.
Esse Quam Videri
Re: My Dyno fetish [Re: quickd100] #2550247
09/15/18 11:36 AM
09/15/18 11:36 AM
nielsville, minn.
Q
Q
nielsville, minn.
I'm too busy listening to your Blues Rich while doing unnatural things to motors!
50 shades of Race Hemi Orange.
Re: My Dyno fetish [Re: quickd100] #2550250
09/15/18 11:39 AM
09/15/18 11:39 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
You two are sick!!!!
Re: My Dyno fetish [Re: ZIPPY] #2550276
09/15/18 12:37 PM
09/15/18 12:37 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
blah laugh2
Used and tossed to the side. laugh2
Re: My Dyno fetish [Re: justinp61] #2550295
09/15/18 01:31 PM
09/15/18 01:31 PM
moparx Offline
moparx  Offline
quickD, you going to try thermoquads on those rams ? how much can a guy learn about long rams from the shorty's ? i'll be watching close ! up
beer
Re: My Dyno fetish [Re: quickd100] #2550314
09/15/18 02:16 PM
09/15/18 02:16 PM
nielsville, minn.
Q
Q
nielsville, minn.
I don't know yet, I would love to see what the Thermoquads would do but I am unsure if I want to cut on these manifolds to do it. Time will tell. It will probably be a couple months yet before I will have the free time to start on it. Potato harvest starts for me on Monday, it's work and sleep with little time for much else.
Re: My Dyno fetish [Re: quickd100] #2550330
09/15/18 03:04 PM
09/15/18 03:04 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A local once dynoed a Hot Saw chainsaw engine.
69 GTX 68 Road Runner
Re: My Dyno fetish [Re: quickd100] #2550356
09/15/18 05:19 PM
09/15/18 05:19 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Hey, I think I might have ALL 50 shades of race hemi orange on the rattle can shelf. Which one dynoed the best? primer shruggy
Re: My Dyno fetish [Re: GomangoCuda] #2550362
09/15/18 05:41 PM
09/15/18 05:41 PM
nielsville, minn.
Q
Q
nielsville, minn.
The shade I had custom mixed at autovalue.
Jeff weren't you at dragweek with Joel?
Re: My Dyno fetish [Re: quickd100] #2550364
09/15/18 05:53 PM
09/15/18 05:53 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
We are on our way home. Just outside of St.Louis right now.
Re: My Dyno fetish [Re: quickd100] #2550366
09/15/18 06:06 PM
09/15/18 06:06 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Been wanting to put my Eddy-headed 496" longrammed engine on the dyno for some time now, but ever since I 'updated' the engine with a solid roller cam it tends to ping.
Re: My Dyno fetish [Re: quickd100] #2550489
09/16/18 12:20 AM
09/16/18 12:20 AM
It would be real interesting to try testing all three versions, lengths, of those early manifolds on the same motor on the same dyno on the same day with the same carbs jetted the same up work hammer wrench grin
Re: My Dyno fetish [Re: quickd100] #2550501
09/16/18 12:47 AM
09/16/18 12:47 AM
nielsville, minn.
Q
Q
nielsville, minn.
I very got my buddy beating the bushes for a set of cheap long Rams to do that very thing Cab. I also have an old 413 single 4 intake.
Re: My Dyno fetish [Re: quickd100] #2550521
09/16/18 02:51 AM
09/16/18 02:51 AM
I miss several opportunity to own several early 300 letter cars with those motors in them whiney realcrazy
I had two early 300 cars, one 1957 C hardtop that was our family car when I first got out of the Army in 1968 and later a 1958 convertible D car, I whup them dual quad 392 Hemi motors regularly hammer boogie devil
On the C car the first long trip we took in that car it blew a hole in the top of #6 piston due to a garage that had done a "valve job" on it shortly before we bought it for that trip, they hadn't torque all the intake bolts down properly and it suck water into #6 coming out of south western Utah into Arizona coming home to SO CA, what a mess whiney
We limp it home using reclaim oil in it, it would go through several quarts per hour. I ended up using a intake and carb off of a 1957 New Yorker on the 300 motor, that woke that lazy rascal right up shock boogie shruggy I also used a piston out of the same New Yorker motor with the original rings from the New Yorker with no honing in that 300 cylinder realcrazy up work shruggy
It was our only car back then so it was fix it as quickly as possible or walk shruggy
Re: My Dyno fetish [Re: quickd100] #2550522
09/16/18 02:57 AM
09/16/18 02:57 AM
P
Porter67 Offline
Porter67  Offline
P
Its funny about the rams, in 82 I went and bought a aftermarket low profile 2x4 intake from the local newspaper ad and he had a set of long rams on the wall, asked if id give $20 for them. My reply was "why".
Re: My Dyno fetish [Re: quickd100] #2550523
09/16/18 02:58 AM
09/16/18 02:58 AM
My squeenter (SP?) muscle still cringes every time I hear one of my motors on a engine dyno going to WOT against the water brake before starting the pulls blush
Good luck on all your testing thumbs
Re: My Dyno fetish [Re: quickd100] #2550540
09/16/18 07:06 AM
09/16/18 07:06 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I like the oddball dyno stuff.
Scott Harms built and dynoed a long ram 413 on here a few years back and that was interesting. I liked your post about the 318 junkyard turbo you did awhile back and your Hemi with the tunnel ram and thermoquads. And just to be sure, you have the "long rams" with the short divider right? (I think they're 16"?). If you could find a long ram with the long divider to compare to and a stock 4bbl that would be icing on the cake. I always thought the long rams would be good for a towing application
Re: My Dyno fetish [Re: quickd100] #2550548
09/16/18 10:12 AM
09/16/18 10:12 AM
nielsville, minn.
Q
Q
nielsville, minn.
They are the short rams, the long Rams have the runner dividers the full length. I am well aquainted with the ram manifolds. An old friend of mine collects the Letter cars and DeSoto Adventures. I have him beating the bushes for a ratty set of long Rams too.
Sometimes it really pays to be in the right place at the right time. There were many stories of how mechanics hated working on the ram cars. More than one talked an owner into ditching them for a single four barrel. They'd throw the rams in the dumpster.
Cab I always laugh when I Dyno a friend's motor and I see that expression of dread and horror on their faces when the dyno loads their motor the first time. I tell them if the motor is built right they have nothing to worry about. If it's a bad one we'll know shortly.
Re: My Dyno fetish [Re: quickd100] #2550553
09/16/18 10:35 AM
09/16/18 10:35 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
When I got my chassis dyno setup, I played with 3 carbs on my old 4x4 with a moderate build 440. The thermoquad made quite a bit more power than the 2 edelbrocks on a performer intake. The bowl eventually cracked and I had to run the edelbrock 750, it never made the same steam. I think this is part of the issue on my dog of a ramcharger current project, is the edelbrock carb just doesn't breathe deep enough, or the performer intake and edelbrock carb combo just doesn't work that well together.
