Hemi converting from 7/16 to 1/2 head studs #2549602
09/13/18 01:42 PM
09/13/18 01:42 PM
Cincinnati, Ohio
d7cook Offline OP
d7cook  Offline OP
Cincinnati, Ohio
My KB block came with 7/16 heads studs. Ken was supposed to make it 1/2" and my heads were drilled for 1/2". Can the block be converted to 1/2 and is it really a necessity to do it. Planning on 12-1, 800 HP build with maybe a 200 shot of nitrous when done. BES said they could do it but the guy on the phone didn't sound super confident when he said it.
Thanks in advance.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Hemi converting from 7/16 to 1/2 head studs [Re: d7cook] #2549605
09/13/18 01:51 PM
09/13/18 01:51 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Not necessary,but a competent machine shop should be able to do it.An alignment tool for the drill and tap procedure is required to keep holes parallel to the deck.
Re: Hemi converting from 7/16 to 1/2 head studs [Re: d7cook] #2549608
09/13/18 01:58 PM
09/13/18 01:58 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You don't need 1/2" for your application. It would cost a lot to ship it to a good shop, then again to ship it back. Then it would cost for the work. Then 1/2" studs would be pricy. I would leave it alone.
2011 Drag Pak Challenger
Re: Hemi converting from 7/16 to 1/2 head studs [Re: rickseeman] #2549644
09/13/18 03:16 PM
09/13/18 03:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree
Re: Hemi converting from 7/16 to 1/2 head studs [Re: d7cook] #2549661
09/13/18 03:52 PM
09/13/18 03:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
BES is great. They can do it no problem. The guy prolly just didn't think you needed it.
Re: Hemi converting from 7/16 to 1/2 head studs [Re: d7cook] #2550965
09/17/18 11:18 AM
09/17/18 11:18 AM
an8sec70cuda Offline
d7cook...you don't need it. My KB hemi has the std. 7/16" studs and makes over 800 hp NA and I've been spraying 250 hp on it for about 4 years.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi converting from 7/16 to 1/2 head studs [Re: d7cook] #2551629
09/18/18 07:10 PM
09/18/18 07:10 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I think like the rest of these guys it's no needed. Your heads are fine with the larger holes.
I'd only do the 5 center (long) ones on both sides, if you are going that way.
