426 Hemi rocker question
#2549207
09/12/18 02:02 PM
09/12/18 02:02 PM
Posts: 1,547 Mattituck NY.
FJ6AAR
Mattituck NY.
Hi, I probably already know the answer to this but I'm wondering what others have to say. My rocker arm assemblies for my 426 hemi are drilled out for 1/2" head bolts. They are not the assemblies that were on the engine the last time it ran. My block is still the standard 7/16". First off, will these work with 7/16" head bolts and maintain proper oil pressure? If not, does anybody know of a crafty fix to try before I search for four oiler rocker stands? thanks in advance, Rob
I want to add that I have a CNC and a few endmils at my disposal so I could machine a bushing for each stand - but I'm hoping somebody has used this combo with success first.
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: 426 Hemi rocker question
[Re: FJ6AAR]
#2549240
09/12/18 03:26 PM
09/12/18 03:26 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
I would fix it The stock steel stands where machined for them,7/16 head bolts with washers and the stock head bolt shoulder size, not bushed, if I'm remembering correctly All the after market stands I've seen had bushings in them
[Re: FJ6AAR]
#2549429
09/12/18 11:28 PM
09/12/18 11:28 PM
FJ6AAR
Mattituck NY.
Thank you for the replies Cab_Burge and Transman. It doesn't appear as though the oil passages in the stands were drilled too. Does anybody know the stock size of those passages so I can measure mine to be sure? If they were not drilled out as well, then I should be good to go.
[Re: FJ6AAR]
#2549459
09/13/18 12:53 AM
09/13/18 12:53 AM
Posts: 3,077 Michigan
A727Tflite
A .250” drill bit fits nicely in those oil passages.
[Re: FJ6AAR]
#2549553
09/13/18 11:46 AM
09/13/18 11:46 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Everything will probably work fine. I would be more concerned with that washer on top having to span a bigger hole. I would be inclined to use this opportunity to acquire a set of those sexy anodized aluminum rocker stands for 7/16" head bolts.
2011 Drag Pak Challenger
[Re: FJ6AAR]
#2549556
09/13/18 12:05 PM
09/13/18 12:05 PM
FJ6AAR
Mattituck NY.
Transman, thank you, I will try one today and hopefully it fits just right.
rickseeman, that was on my mind too. If I had the additional funds I would buy a nice sexy set...lol I'm going to look at McMaster-Carr and try to find a hardened - larger diameter washer with the same ID for just that purpose.
