A904 - front band Kevlar - pictures #2548579
09/10/18 11:49 PM
09/10/18 11:49 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello guys,
the shop rebuilding my A904 is concerned about the difference of the front double Kevlar band I've bought. It´s wider and looks like it wont be well centralized with the strut.
Do you have any pictures of your transmission being rebuilt?
https://drive.google.com/open?id=1QT6zA2iuQsQtiMC1gGVhw4H-Y2JrFlwL
1973 Brasilian Dart
E100, boosted 390"
Re: A904 - front band Kevlar - pictures [Re: dart_73_br] #2548662
09/11/18 06:29 AM
09/11/18 06:29 AM
Guitar Jones Offline
No reason it shouldn't work. Some guys are just nervous about anything that doesn't look exactly like the part they are replacing.
Re: A904 - front band Kevlar - pictures [Re: dart_73_br] #2548796
09/11/18 02:31 PM
09/11/18 02:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If your 904 front clutch drum originally used the 1.4" wide band, the 1.6" wide band won't work; the 1.6" band is for the later A999 and OD variations with a wider drum.
When the wider drum was introduced in '74, the extra width was added to the front of the drum so this necessitated offsetting the strut interface.
