Any Input on Bill Mitchell Blocks lately? #2548766
09/11/18 01:41 PM
09/11/18 01:41 PM
USA
hudsonhornet7x Offline OP
USA
What are the pitfalls if any on current Bill Mitchell hemi blocks? How is the machining, what do I need to look out for, etc?
Thanks for any help. I am looking for a Hemi block for the street.
Re: Any Input on Bill Mitchell Blocks lately? [Re: hudsonhornet7x] #2548804
09/11/18 02:47 PM
09/11/18 02:47 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Here's what I can tell you about my RB block. I should be getting it from the builder very soon. It went back last August due to a machining / core error in the oiling system. The oil port in the front of the block used to bypass an internal pickup intersected the oil pump drive shaft bore causing it to suck air. The only other issue I had was I ended up running a tall roller lifter due to the bronze bushings being tall.
What I can say is that Bill Mitchell was very helpful in getting my issues fixed with the oiling system and great to work with. My block was purchased in Jan 2017
Re: Any Input on Bill Mitchell Blocks lately? [Re: JACK1440] #2548806
09/11/18 02:54 PM
09/11/18 02:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
August of 2017 or August of 2018?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Any Input on Bill Mitchell Blocks lately? [Re: pittsburghracer] #2548825
09/11/18 03:30 PM
09/11/18 03:30 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
These things matter to old guys.
Re: Any Input on Bill Mitchell Blocks lately? [Re: hudsonhornet7x] #2548872
09/11/18 05:05 PM
09/11/18 05:05 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
lol..... unfortunately it was August 2017 when I returned it. The bad thing about that is you think during down time. Since then it grew from 557" to 572", up a point of compression to 15:1 and bigger -1 heads.
Re: Any Input on Bill Mitchell Blocks lately? [Re: JACK1440] #2549011
09/11/18 10:34 PM
09/11/18 10:34 PM
Idaho
LaRoy Engines Offline
Idaho
Same problem here. I plugged the block and went to an external oiling system. I received this block over a year ago. I'd have to go back into the paperwork to figure out the exact number of months.
Also the oil passages through the block didn't line up and 9/16" diameter intersections were only 3/16" so I had to do a bunch of re-drilling.
The bronze lifter bushings were so out-of-round that by the time they were honed round they were too big. Fortunately the lifer bores in the block were round so I replaced the bushings and honed them correctly.
The block decking wasn't anywhere near lined up with the crank and cam tunnels.
The rear main oil seal bore was some weird size that no main seal on the planet would fit. Unless Bill Mitchell had something special tucked away.
Before the block arrived I was told on the phone, "Let us know what you think and how the block turned out."
I couldn't get Bill Mitchell to return my calls or emails. I was left completely on my own to fix the problems.
Re: Any Input on Bill Mitchell Blocks lately? [Re: LaRoy Engines] #2549189
09/12/18 01:15 PM
09/12/18 01:15 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I have to correct myself... I've had my block since March of 2016. The issue from last August was that it had oil pressure but cooked rod bearings on rods 3,4,5 & 6 but the mains looked good. That's why we suspected air. That failure threw a rod cap and ended up messing up 2 bores. So Bill sent it to Ray Barton who did the repair work with 2 new sleeves. How did you find you had bad oil passages?
Re: Any Input on Bill Mitchell Blocks lately? [Re: JACK1440] #2549635
09/13/18 03:01 PM
09/13/18 03:01 PM
Idaho
Idaho
It was a simple as shining a light into the passages to see the junctions.
Re: Any Input on Bill Mitchell Blocks lately? [Re: hudsonhornet7x] #2549720
09/13/18 06:53 PM
09/13/18 06:53 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
gotcha.. thanks! gonna make sure that happens.
Back to the first question.... I'm not sure the blocks are available. You would have to call
Re: Any Input on Bill Mitchell Blocks lately? [Re: hudsonhornet7x] #2549802
09/13/18 11:51 PM
09/13/18 11:51 PM
USA
USA
Bill says the blocks will be available late November if everything goes right. Just talked to him yesterday on the phone.
Re: Any Input on Bill Mitchell Blocks lately? [Re: hudsonhornet7x] #2550006
09/14/18 03:38 PM
09/14/18 03:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hell maybe I could buy another one smile
