Front coil over spring rate? #2547589
09/08/18 01:31 PM
09/08/18 01:31 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Hello y’all
I am trying to get some weight and adjustability in the front of my B Body drag car. I hope this group can help me.
I have Magnum Force Upper control arms and HDK bolt on upper coil over mounts.
I have lots of shocks set up for coil over mounts from my dirt track days and I want to use those if possible. Easy ups, hold downs, 50-50, etc...I have the QA1 shock specs from HDK so I’m good as far as compressed/ extended lengths so I’m good there, but I do not think 3 in travel is enough for what I want to do. What I I need help/ advise with is a beginning spring rating. I want to know what spring I need to get stock ride height.
Does anyone know a starting weight rating, or a usable calculator? I have done a google search for a conversion calculation but evidently I am not smart enough to use them.
My thoughts are to remove the torsion bars and use the shocks/ coil overs to tune the front rise/ fall rates without changing ride heights. It’s worth a try I think.
Thanks in advance.
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: Front coil over spring rate? [Re: mopar97] #2547612
09/08/18 02:17 PM
09/08/18 02:17 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I'm not sure on a chart. I have an HDK k member with Summit brand coil overs. I went with the recommended 450# springs. It's great on the street. I spoke with Denny not to long ago. He recommended 300# springs for my Dart. I haven't put them on yet though. I would give Denny a call and see what he says.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Front coil over spring rate? [Re: dart440_72] #2547676
09/08/18 07:44 PM
09/08/18 07:44 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Thank you! What part number Summit Coil over?
Re: Front coil over spring rate? [Re: mopar97] #2547677
09/08/18 07:46 PM
09/08/18 07:46 PM
P
Porter67 Offline
Porter67  Offline
P
What does your front weigh?
Ive #350 on my a body coil over car, #300 was a no go if you still drive on the street and have a pan or trans pan within 2 inches of the road.
Re: Front coil over spring rate? [Re: Porter67] #2547788
09/09/18 01:20 AM
09/09/18 01:20 AM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
It’s a full body with fiberglass hood, fenders, and bumper but it still has the inner fenders. I don’t think it’s lost over 100 lbs. 350 bottoms out so the 450 May be the way to go?
Thank you
Re: Front coil over spring rate? [Re: mopar97] #2547838
09/09/18 10:35 AM
09/09/18 10:35 AM
gregsdart Offline
gregsdart  Offline
I would go with the softest spring that won't coil bind at any part of travel. Then control the rate of rise or compression with shocks.
Re: Front coil over spring rate? [Re: mopar97] #2547839
09/09/18 10:39 AM
09/09/18 10:39 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I run 450 on my Cuda with a MF kit....I switched to Viking shocks with longer extension to allow more travel.
Re: Front coil over spring rate? [Re: mopar97] #2547842
09/09/18 10:51 AM
09/09/18 10:51 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Mine are part number SUM-G773601
I'm an A body though
Re: Front coil over spring rate? [Re: Porter67] #2547843
09/09/18 10:52 AM
09/09/18 10:52 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Thanks for the heads up on this. I have 300# waiting in my garage to put on. Is weight transfer better with the 350#'s
Re: Front coil over spring rate? [Re: mopar97] #2547888
09/09/18 12:24 PM
09/09/18 12:24 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
The heavier the spring, the stiffer the suspension. Lower pressure springs will give you quicker weight transfer, but will bottom out faster when street driving.
[image][/image]
Re: Front coil over spring rate? [Re: sgcuda] #2547892
09/09/18 12:33 PM
09/09/18 12:33 PM
Exactly...The spring has to be compressed to store the energy...
Re: Front coil over spring rate? [Re: Dragula] #2547961
09/09/18 03:05 PM
09/09/18 03:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
True. Lighter springs will have to be compressed more to support a given amount of weight at a given ride height. This makes the suspension more "lively", stores energy in the spring and helps with separation. A good DA shock is needed to control the suspension when going this route, front or rear.
Re: Front coil over spring rate? [Re: sgcuda] #2548148
09/09/18 10:54 PM
09/09/18 10:54 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Thanx for the assistance..
