Howards cams and lifters #2547705
09/08/18 09:44 PM
09/08/18 09:44 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I need to replace my cam and I'm looking at some nice grinds from Howards and they have some good reviews. Still on the fence on which way to go as I hardly ever race may car anymore. Have been considering hydraulic roller or EDM lifter solid flat cam shruggy
I shift my car at 6500 when I'm whooping on it but most of the time it runs around 3000 so a solid roller wouldn't really be a wise choice for street cruiser. My old solid has been in there about 6 years and I have a few lobes going away after I overheated it last summer,at least that's when the trouble started. Are hydraulic street rollers any better than they used to be?
Are the rollers with direct oil to the bearings OK for street use or is that some marketing hype?
Thanks for any advice thumbs
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howards cams and lifters [Re: fourgearsavoy] #2547709
09/08/18 09:55 PM
09/08/18 09:55 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have ran a Howard's hydraulic roller on the street for over 5000 miles and lots of dragstrip use in the last couple of years. I never rev the engine over 6,500 so it works perfect for me. Very happy with its performance.
A friend was having problems with Comp hydraulic roller lifters. He replaced them with the same ones that I use from Howard's and the problems all went away.
I'd also recommend the Howards fuel pump push rod and the crane 66970 - 1 coated gear to go with it. Both seem to be holding up really well!
'63 Dodge 330
11.19 @ 121 mph
Re: Howards cams and lifters [Re: fourgearsavoy] #2547714
09/08/18 10:04 PM
09/08/18 10:04 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The only Howard that I've used was in a SB Chevy 427 stroker and it was awesome. Was a hydraulic roller
Have a friend that has used a few in Mopars and has been happy with them except the last one. It was warped and wouldn't fit in the block. They did replace it and the new seemed to fit good.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Howards cams and lifters [Re: fourgearsavoy] #2547717
09/08/18 10:08 PM
09/08/18 10:08 PM
crabman173
crabman173
Howards does GREAT job on cams--Just do NOT use the Comp hyd rollers or the Johnsons see what Howard has I think they are reboxed Morels--ASK
SOOO many people FAIL to observe the Morel spring pressure advice
145 seat and 340 open max on std hyd roller
You can spend a lot more for lifters with different vlaving so that you can run more pressure for more RPM but then preload gets very critical etc
Morel is also very specific about preload usually 1/4 turn
Please Please be aware of the needs of the lifters you actually wind up with and if you get Morel made you can rest easy as long as you ADHERE to what they say
Re: Howards cams and lifters [Re: fourgearsavoy] #2547727
09/08/18 10:39 PM
09/08/18 10:39 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Have a Howards solid lifter cam and the edm lifters with the oil hole in the face they sell.
Couldnt be happier, nice stuff
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Howards cams and lifters [Re: ] #2547729
09/08/18 10:45 PM
09/08/18 10:45 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
we put a Howards solid cam and edm lifters in a buddys 451 also the Howards roller timing set and brought his car to life and it has been in for approx 3 years and never a problem, they make good stuff and well worth the money spent. up
Re: Howards cams and lifters [Re: fourgearsavoy] #2547759
09/08/18 11:53 PM
09/08/18 11:53 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run the Howards lifters in both of my wedge motors . No dramas whatsoever .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Howards cams and lifters [Re: fourgearsavoy] #2547766
09/09/18 12:20 AM
09/09/18 12:20 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the High rpm Morel's, hydro roller, so far 2k miles & some 1/4 mile passes.
Re: Howards cams and lifters [Re: CSK] #2547797
09/09/18 02:04 AM
09/09/18 02:04 AM
Rittman Ohio
Rittman Ohio
I have read some things that indicate the Howards lifters and Morels are the same ones.
Thanks for all the replies so far I think I may go flat EDM solid because I like the quick RPM's with a stick car.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howards cams and lifters [Re: fourgearsavoy] #2547811
09/09/18 05:49 AM
09/09/18 05:49 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I haven't put any miles on the car yet, but I went with Howard's EDM lifters on my Scott Brown solid lift cam. I'm hoping for some good mileage out of them.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Howards cams and lifters [Re: fourgearsavoy] #2547909
09/09/18 01:21 PM
09/09/18 01:21 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I use their cam, Howards solid lifter cam and the edm lifters with the oil hole in the face also, pulls a lot harder than my old cam!
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Howards cams and lifters [Re: fourgearsavoy] #2548126
09/09/18 10:05 PM
09/09/18 10:05 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I run this cam and EDM lifters, as well as their double roller chain.
My Fury has a 520" TF 240 headed engine and 4 speed it runs great.
https://www.howardscams.com/mechanical-f...-howards-cams-0
https://www.youtube.com/watch?v=7ygXG7bcL2o
https://www.youtube.com/watch?v=WAi5keVD_N4
Re: Howards cams and lifters [Re: 65Fury440] #2548210
09/10/18 01:30 AM
09/10/18 01:30 AM
Rittman Ohio
Rittman Ohio
That sounds very good and the grind is close to what I'm wanting. Did you have to specify EDM lifters or did the cam come with them. Your heads probably flow close to my Indy EZ's with standard ports so that cam should work with my combo 10.9 to 1 compression.
Sounds like it works nice with a stick car drive
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howards cams and lifters [Re: fourgearsavoy] #2548303
09/10/18 11:30 AM
09/10/18 11:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a Dwayne Porter solid flat tappet that's 264 & 270 @ .050 with .585 & .592 lift and a 110 LSA. I use the EDM lifters that Dwayne supplied and have been running this setup since 2011 with no problems ever. I do a lot of street driving and a little racing of maybe once a year lately. Ron
Re: Howards cams and lifters [Re: fourgearsavoy] #2548545
09/10/18 10:15 PM
09/10/18 10:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Gus, when you decide on what cam and lifters you want you can call Howards but when we ordered the parts for Walts car the guy at howards told us to order it thru Competition Products which is next door to Howards and they will have a better price,I believe it has somthing to do with not undercutting their dealers on pricing.
Re: Howards cams and lifters [Re: 65Fury440] #2548605
09/11/18 12:38 AM
09/11/18 12:38 AM
Originally Posted By 65Fury440
That be a big street cam up bow
Your my kind of street car driver devil whistling hammer
Re: Howards cams and lifters [Re: fourgearsavoy] #2548610
09/11/18 12:47 AM
09/11/18 12:47 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Well, he does have 520 ci so .616/.620, 260/264@.050 isn't THAT huge wink
Re: Howards cams and lifters [Re: fourgearsavoy] #2548846
09/11/18 04:08 PM
09/11/18 04:08 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Gus beer
I ordered up the cam, chain, and lifters separate, talked to a couple guys at Howard's, was impressed at their attitude, very helpful.
I had Larry Smith port my 240s up to MW size to fit my 337 intake, I think he said they flowed like 360 if I recall correctly.
I have been getting it sorted out, your car is probably way lighter than mine, should work well for you.
It is a little big for my 2 ton car with a 3.54 gear, but once she's rolling she gets.
Re: Howards cams and lifters [Re: Cab_Burge] #2548847
09/11/18 04:09 PM
09/11/18 04:09 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
It is a lil big, nothing a 4.10 gear won't cure.
Re: Howards cams and lifters [Re: DrCharles] #2548850
09/11/18 04:11 PM
09/11/18 04:11 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I have the cam advanced 8 degrees, bumped cylinder pressure up to 180 psi from 165ish, really cleaned it up down low.
