Re: Will stock valve covers fit on Indy 440-1 heads?
[Re: FastmOp]
#2547681
09/08/18 08:30 PM
09/08/18 08:30 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm going to use 440source covers on my B1 engine Untitled by John Cadamore, on Flickr
[Re: 72demon416]
#2547744
09/08/18 11:07 PM
09/08/18 11:07 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
-1 and SR have the same vc rail.
[Re: 72demon416]
#2547896
09/09/18 12:35 PM
09/09/18 12:35 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Gasket pattern is stock, and for the most part, yes, stock valve covers will work. Depending on valve lift and rocker design, I would be checking clearances for rockers and shaft hold downs. How stock are you talking? OE valve covers or aftermarket replacements? I've had Milodon stamped aluminum valve covers that needed massaging fitting my shaft hold downs and Harland Sharps on 915 heads.
[image][/image]
[Re: 72demon416]
#2548246
09/10/18 02:50 AM
09/10/18 02:50 AM
Posts: 10,022 MN
JERICOGTX
MN
Depends on how "stock" you want the engine to look.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2548247
09/10/18 02:55 AM
09/10/18 02:55 AM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Yeah, sorta like that. For this car I’ll probably stick a little closer to stock appearing then what I’ve done in the past (like your pic) but I will likely try hide some heads. Are those, ez’s, sr’s, 440-1’s? Looks good no matter what!!
[Re: JERICOGTX]
#2548295
09/10/18 11:08 AM
09/10/18 11:08 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Depends on how "stock" you want the engine to look. Now that is cool! I like how you even painted the meziere water pump to blend w the rest. Sneaky and I like it!
2 kids and a dog
[Re: dvw]
#2548353
09/10/18 01:13 PM
09/10/18 01:13 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Bondo up the Indy logo and paint it all. These are Indy covers. Though this is to racey you can get the idea. Doug Who's thermostat swivel upper radiator hose fitting is that? I like it
