1970 cuda non ralley dash harness to ralley dash conversion #2547378
09/07/18 09:28 PM
09/07/18 09:28 PM
New York
flitesweep Offline OP
New York
Has anyone done this conversion? what do I have to splice and or make? I am also looking for the rear backup light single wire metal sockets that are attached to the wiring harness, mine are missing. they push into the tail light housings. does anyone knows where I can get those. thanks.
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: flitesweep] #2547386
09/07/18 09:43 PM
09/07/18 09:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
There is nothing wrong with a standard dash cluster.
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: flitesweep] #2547438
09/08/18 12:47 AM
09/08/18 12:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've done this "conversion", your best to get/download a FSM for the wiring diagrams, it helps avoid a lot of head scratching, the speedo hook up is straight forward, uses the same cable you have, the tach set up will require you to run a wire to the negitive side of the coil, you'll need to either alter/lengthen the ends of the fuel, oil and temp harness wires, your amp gauge wires will hook up with no mods, you'll need to change the engine's oil sender unit over to the "gauge" style sender, and you'll need to get a hot lead over to the clock, the radio plate from your standard cluster will work with the ralley dash, however you need the ralley dash heater control panel, and the ralley dash switch panel, the current switches from your standard dash are the same and can transfer over into the ralley switch panel, generally you'll need the ralley dash light panel located under the gauge ridge of the padded dash, if you don't have it, the standard light panel still fits into place, just that the lighting is not illuminated properly at the ralley gauge pod locations, I'm sure I may have missed a few items electrically, but mark all the connections from the standard dash as you remove them so you don't mistaken the wrong wires/connections, make sure on the Ampmeter hook up that red goes to red, black to black for proper function, as well as making sure the Amp gauge hook ups are properly isolated from grounding out on the dash/instrument cluster, as this is your biggest source of fire/failure
Mike
here's a few pics...
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: Alaskan_TA] #2547486
09/08/18 07:47 AM
09/08/18 07:47 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have an ex-wife who thinks her opinion is more important than actually answering the question.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: flitesweep] #2547488
09/08/18 07:52 AM
09/08/18 07:52 AM
moparmarks Offline
moparmarks  Offline
Mike pretty much summed it up. I'll add that the standard cluster has an oil light so that bulb socket needs the be changed to a terminal for the oil gauge. The leads for the fuel and temp can reach the Rallye gauges with a little finagling. You'll need to tap into the blue ignition wire for the power to the tach.
Is a pretty easy conversion.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: flitesweep] #2547492
09/08/18 08:27 AM
09/08/18 08:27 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
RTE makes an adapter harness for this.
https://www.ebay.com/itm/162766275415
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: larry4406] #2547527
09/08/18 11:11 AM
09/08/18 11:11 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Nice to know..Thanks Larry
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: flitesweep] #2547645
09/08/18 05:04 PM
09/08/18 05:04 PM
New York
New York
Thanks for all of the great info, I ordered the conversion kit. One other question I have is the dash frame, is there anything different ralley versus non ralley? I have read conflicting information..
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: flitesweep] #2547652
09/08/18 05:35 PM
09/08/18 05:35 PM
moparmarks Offline
moparmarks  Offline
Dash frames are the same.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 1970 cuda non ralley dash harness to ralley dash conversion [Re: flitesweep] #2547798
09/09/18 02:11 AM
09/09/18 02:11 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
As noted by moparmarks they're the same, it's the 69-70 B body dash frames that are different when going ralley
