Gluing Intake gaskets together #2547273
09/07/18 05:21 PM
09/07/18 05:21 PM
West Virginia
Mirada 408 Offline OP
West Virginia
To make a long story short, i need to glue 2 intake gaskets together per side on my 360 magnum. Looking for advice on what to use to glue them together? and should i glue them together, put some clamps on it, and let it sit overnight? Or put them together and then bolt intake down etc?
Re: Gluing Intake gaskets together [Re: Mirada 408] #2547275
09/07/18 05:34 PM
09/07/18 05:34 PM
West Virginia
West Virginia
I forgot about the edelbrock intake gaskets, which are .060 thick. i was using felpro MS95392-1, anyone know how thick these are?
Re: Gluing Intake gaskets together [Re: Mirada 408] #2547308
09/07/18 06:51 PM
09/07/18 06:51 PM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
Check out the catalog at Superformance, they have a few different thicknesses. Best gaskets you'll buy.
Re: Gluing Intake gaskets together [Re: Mirada 408] #2547313
09/07/18 07:01 PM
09/07/18 07:01 PM
I've had to stack intake gaskets on more than one Mopar V8, SB, BB and Hemiroid motors. If you are using only two try sealing one, I like and use gasket cinch for that up, on the head and the other on the intake manifold up scope
Re: Gluing Intake gaskets together [Re: Mirada 408] #2547406
09/07/18 10:45 PM
09/07/18 10:45 PM
I've used Indian head cement on all 4 sides (of 2 gaskets per side) & especially on the flow thru water ports in the front.
Re: Gluing Intake gaskets together [Re: RapidRobert] #2547444
09/08/18 12:58 AM
09/08/18 12:58 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
There was another post on this subject and this was highly recommended.
http://www.valco-cp.com/Hylomar.htm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Gluing Intake gaskets together [Re: pittsburghracer] #2547451
09/08/18 01:20 AM
09/08/18 01:20 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I can't say enough good things about Hylomar. I use it for everything, it will even reseal RTV!
