Page 4 of 4 1 2 3 4
Re: Change in plans [Re: ZIPPY] #2546218
09/05/18 03:23 PM
09/05/18 03:23 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Originally Posted By ZIPPY
Let's see that cool looking hood scoop...
Probably nothing that hasn't been posted here at some point in the past, but since I don't feel like digging around for pics in old posts...
Re: Change in plans [Re: racerx] #2546229
09/05/18 03:33 PM
09/05/18 03:33 PM
BradH Offline OP
BradH  Offline OP
Originally Posted By racerx
I like the red pin stripe on the grill up
I wanted the entire grill blacked out, but Mike thought the bright trim still looked decent enough that he put it back on. I think the red stripe was from the factory... I may go "full black" anyways, if I don't want to look at the "fish mouth" grill any longer.
Also the crack on the left front frame rail is this common on the mopars ? I think someone else has found a crack on the frame rail, Doug with the 64 dodge I believe shruggy
No idea. Mine had the rust hole in the frame when I bought it, but I'm pretty sure the cracks developed during the time I've owned it. I figure that every time it came off the line w/ the front wheels jerked 4-6 inches in the air that there was some stress being applied around the front suspension, etc.
Re: Change in plans [Re: BradH] #2546230
09/05/18 03:34 PM
09/05/18 03:34 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Lookin good Brad! I also found a crack on the front driver's side frame rail of my cuda. Near the front K frame bolt. Welded a patch over it and no more problems...been that way since the car was running in the 10s, so 2003 or so?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Change in plans [Re: BradH] #2546252
09/05/18 04:05 PM
09/05/18 04:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Love the scoop.
Rich H.
Esse Quam Videri
Re: Change in plans [Re: fast68plymouth] #2546381
09/05/18 08:43 PM
09/05/18 08:43 PM
BradH Offline OP
BradH  Offline OP
Originally Posted By fast68plymouth
Originally Posted By Triple Threat
Looks good, any progress is good progress.
Exactly.
Looks like Mike is getting right after it!!
Yep. He told me today his work will be done by the weekend, so the car should be returning to La Casa de Chaos soon.
Now it's up to me -- again -- to make sure things keep moving in the right direction. whistling
Re: Change in plans [Re: BradH] #2546781
09/06/18 04:49 PM
09/06/18 04:49 PM
AndyF Online content
AndyF  Online Content
Did you put the fuel pump inside the tank with the new setup? I think tanks with internal pumps are a bolt in deal for E body cars now.
Re: Change in plans [Re: AndyF] #2546821
09/06/18 06:23 PM
09/06/18 06:23 PM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
Just looking at the Holley EFI Tank page the other day. Nearly everything but the early B's now. Here's the E body tank.
https://www.holley.com/products/ls_power/fuel_tanks/parts/19-137
Re: Change in plans [Re: AndyF] #2546856
09/06/18 07:36 PM
09/06/18 07:36 PM
BradH Offline OP
BradH  Offline OP
Naah... had purchased a standard replacement tank and a spare Mallory 140 pump quite a ways back... simpler & cheaper to do a basic parts swap at this point.
Re: Change in plans [Re: BradH] #2551659
09/18/18 08:33 PM
09/18/18 08:33 PM
BradH Offline OP
BradH  Offline OP
Mike's work is done and the MoRust -- uh... MoPig -- is back home.
Car-side of garage is cleaned up; work-side of garage still needs some attention before I start wrenching again.
These semi-crappy pics don't look much different than what's been posted before, but they're as of Sunday afternoon once the car came back.
Another few good looks at that big ugly mother-effing scoop, too.
The project will continue...
Re: Change in plans [Re: BradH] #2551660
09/18/18 08:34 PM
09/18/18 08:34 PM
BradH Offline OP
BradH  Offline OP
Re: Change in plans [Re: BradH] #2551661
09/18/18 08:36 PM
09/18/18 08:36 PM
BradH Offline OP
BradH  Offline OP
Re: Change in plans [Re: BradH] #2551664
09/18/18 08:40 PM
09/18/18 08:40 PM
BradH Offline OP
BradH  Offline OP
Re: Change in plans [Re: BradH] #2551666
09/18/18 08:43 PM
09/18/18 08:43 PM
BradH Offline OP
BradH  Offline OP
Re: Change in plans [Re: BradH] #2551669
09/18/18 08:45 PM
09/18/18 08:45 PM
BradH Offline OP
BradH  Offline OP
TTFN wave
Page 4 of 4 1 2 3 4
