Page 3 of 3 1 2 3
Re: Need help tuning dominator for the street [Re: Thumperdart] #2538943
08/20/18 11:49 AM
08/20/18 11:49 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Originally Posted By Thumperdart
Originally Posted By an8sec70cuda
Mine has a PV on the primary side BTW. It is far from a blubbery mess.
Guess I'm the odd man out in this conversation...different observations about a couple different carbs I've had here.
Glad that works for you and apparently you got a good tune going............ thumbs Do you have a wide band to verify afr's at different engine speeds.......... beer Just asking to get info and understand how you verify that your 3-circuit is great on the street and has no blubbery or over rich issues cos if so, that's a good thing for sure just haven't seen it first hand.......... thumbs
No wideband needed. After 12 years of street and strip use and never fouling plugs and running great, I'm perfectly happy w/ it. Sounds crisp, clean off the footbrake or the transbrake. Part throttle driving around town, no stumbles, or running rough. Which is a lot more than I can say for some other carbs I've had to mess with.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need help tuning dominator for the street [Re: an8sec70cuda] #2539025
08/20/18 02:01 PM
08/20/18 02:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs And the mighty HEMI likes fuel so maybe it's happy as you said and needs it........... beer
Re: Need help tuning dominator for the street [Re: Canam800] #2546479
09/06/18 12:27 AM
09/06/18 12:27 AM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
Got the carb back from Dominic and back on the car. What a difference. The car runs great. Way cleaner and smoother. Going to take it out and drive it more only got to put a few miles on it. When it stops raining here I will log some more miles and report back . Very happy so far. Night and day difference very responsive. Thanks Dominic.
Thanks Brandon
Re: Need help tuning dominator for the street [Re: Canam800] #2546520
09/06/18 01:42 AM
09/06/18 01:42 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks Brandon
Was wondering how it worked out as I haven't heard from you guys and I start twitching in anticipation............Very happy that you're happy......... thumbs
Re: Need help tuning dominator for the street [Re: Canam800] #2546695
09/06/18 02:18 PM
09/06/18 02:18 PM
To many people think that carbs are no good, they do not realized that all carbs. are tuneable wrench Some are harder to tune than others shock whistling
I've told many racers and hot rodders to tune one circuit at a time , starting with the idle circuit and then move up to the transition circuit and so on up
With todays parts like wide ban O2 system you can dial most carbs in to perfection boogie wrench grin
The bad part is some guys say more about this subject than they understand shock work shruggy
My message on this is not all motors like the same tune up or parts so experiment and test, test and test some more until you get it exactly the way YOU like it up
Re: Need help tuning dominator for the street [Re: Thumperdart] #2546842
09/06/18 07:16 PM
09/06/18 07:16 PM
PA
Harry's Taxi 2 Offline
PA
Thanks Brandon
Thumper, could you give us the "recipe" you used for this application?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Need help tuning dominator for the street [Re: Harry's Taxi 2] #2546855
09/06/18 07:36 PM
09/06/18 07:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
They vary but if you send yours you can see for yourself my "recipe"........ biggrin beer
I look at the whole picture of the said vehicle and it's intended application and go from there but lets just say I tune like the baddest did in the 60's and 70's not like the monkey crap you see today........Less emulsion(2)normally and adjustable t-slot jets to keep em clean n mean till you wood the happy peddle.......... drinking
Re: Need help tuning dominator for the street [Re: Thumperdart] #2547213
09/07/18 02:36 PM
09/07/18 02:36 PM
dogdays Offline
dogdays  Offline
Thumper needs to eat, too!
R.
Re: Need help tuning dominator for the street [Re: Canam800] #2547324
09/07/18 07:18 PM
09/07/18 07:18 PM
PA
PA
dogdays, I understand that, but per thumpers own acknowledgment he was given quite a bit of free guidance in the past. I gotta eat too!
Re: Need help tuning dominator for the street [Re: Harry's Taxi 2] #2547340
09/07/18 07:50 PM
09/07/18 07:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nothing is free I'm here to tell ya..........Hundreds and hundreds of dollars on gas, plugs, oil, tires etc to learn this stuff and am still learning new and unexpected stuff. My numbers below if you want to call me anytime.......... thumbs And let's just say that the "free" info isn't always accurate.............. beer
Re: Need help tuning dominator for the street [Re: Canam800] #2775707
05/18/20 12:59 PM
05/18/20 12:59 PM
Ashburs, Virginia, USA
LayDeluca Offline
LayDeluca  Offline
Hello... i can say you need to try is setting the Closed Loop Compensation Limits down.
In my case I pulled the distributor to find that the gear is pretty worn on the bottom leading edges of the teeth. It looks like I need to figure out a way to get my distributor depth just a little deeper. This would explain my jumpy timing.
pcb manufacturing
Page 3 of 3 1 2 3
