Cooling testing
#2546768
09/06/18 04:36 PM
09/06/18 04:36 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I just wanted to share some of the most scientific coolant testing that I am capable of. I have been chasing cooling issues for a while so I thought I would play with different restrictors, thermostat, and open system.
This is what I found:
Outside temp 75 Lower hose 137 Upper hose 98 Car holding at 186 Restrictor 3/4"
Outside temp 75 Lower hose 132 Upper hose 100 Car holding 196 Restrictor 1"
Outside temp 75 Lower hose 128 Upper hose 91 Car holding 188 180 thermostat
Outside temp 75 Lower hose 142 Upper hose 93 Car holding 197 Open system
Outside temp 75 Lower hose 131 Upper hose 92 Car holding 198 Restrictor 5/8"
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Cooling testing
[Re: dart440_72]
#2546783
09/06/18 04:52 PM
09/06/18 04:52 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Why is the upper hose colder ? reverse flow ?
Re: Cooling testing
[Re: dart440_72]
#2547057
09/07/18 03:33 AM
09/07/18 03:33 AM
RapidRobert
I have been chasing cooling issues for a while so I thought I would play with different restrictors, thermostat, and open system. what system/parts/tuning/symptoms do you have?
Re: Cooling testing
[Re: dart440_72]
#2547077
09/07/18 09:22 AM
09/07/18 09:22 AM
dart440_72
Medina, OH
I have a griffin radiator, flowkooler pump, with a 1:1 pulley ratio. I am trying to figure out why my upper hose is cooler than my lower. I tested the pump and it is pushing water out the top hose. But I can't understand why the top hose would be cooler than the bottom
