440 in a 78 Dodge which frame holes #2544921
09/03/18 02:47 AM
09/03/18 02:47 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Motor mounts aren't lining up.which set of holes do I use front or back.2Wd mounts are curved and not straight.
Re: 440 in a 78 Dodge which frame holes [Re: chargers777] #2544928
09/03/18 03:14 AM
09/03/18 03:14 AM
Nashport, OH
Nashport, OH
Are 2wd mounts straight or curved
Re: 440 in a 78 Dodge which frame holes [Re: chargers777] #2544939
09/03/18 04:41 AM
09/03/18 04:41 AM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
2wd mounts are straight.
Re: 440 in a 78 Dodge which frame holes [Re: chargers777] #2546468
09/06/18 12:08 AM
09/06/18 12:08 AM
Nashport, OH
Nashport, OH
Which holes?anyone? My mounts are curved and it's a 2 wd.
Re: 440 in a 78 Dodge which frame holes [Re: chargers777] #2549948
09/14/18 01:20 PM
09/14/18 01:20 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'll check tonight when I get home.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 440 in a 78 Dodge which frame holes [Re: chargers777] #2550214
09/15/18 09:32 AM
09/15/18 09:32 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Here's a photo of the D code Ramcharger before I swapped the G3 in to it. Big block 4x2 uses the back holes in the Crossmember.
With the 4x4 mounts you should be able to use the front holes,
the bottom photo is of a 4x4 Ramcharger converted over to 4x2 and I used the 4x4 mounts in the SB hole(forward holes).
Re: 440 in a 78 Dodge which frame holes [Re: chargers777] #2550216
09/15/18 09:42 AM
09/15/18 09:42 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 440 in a 78 Dodge which frame holes [Re: chargers777] #2550254
09/15/18 11:43 AM
09/15/18 11:43 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
chargers777 as you look at MoparMarks Photo , the mounts top left are 4x2 and the ones top right are 4x4s
Not to sound like an A$$ or insult your intelligence , but , if you have the 4x4 mounts make sure the round hole goes over the oil pump...…..I've seen people make that mistake.
Re: 440 in a 78 Dodge which frame holes [Re: ric3xrt] #2550533
09/16/18 04:29 AM
09/16/18 04:29 AM
Nashport, OH
Nashport, OH
Thank you both for the help and great pics! Much appreciated.I got it in using the front holes.Evidently I have 4x4 mounts.
